• 24.09.2026, 09:43
adwhitworth
Typ1 or Typ2?
Donnerstag, 29. Mai 2003, 12:30
Hallo, spreche ich nicht Deutsches, also habe ich dieses mit Babelfish Altavistas umgewandelt. Ich werde wirklich gehaftet auf, welchem Block ich für mein Northbridge benötige. Es ist für eine Granit-Bucht (Asus P4G8X). Mein lokaler Verteiler kann sie für uns bestellen, aber wir sind nicht sicher, die einer wir aus dem Typ1 oder dem Typ2 heraus benötigt. Dank für irgendwelche hilft im voraus. ??? :)
If that doesn't come out right and some of you can speak English, this might be easier to understand.
Hello, I don't speak German so I have converted this with Altavista's Babelfish.
I am really stuck on which block I need for my Northbridge. It is for a Granite Bay (Asus P4G8X). My local distributor can order them for us but we are not sure which one we need out of the Typ1 or Typ2.
Thanks for any help in advance.
Adam
Markipuh
Re: Typ1 or Typ2?
Donnerstag, 29. Mai 2003, 12:48
hi and welcome to the AC-Forum!
there has not been released a version of the Twinplex for Granite Bay yet! but AC will present o special one in the next weeks! that special version will base on the ordinary Twinplex for chipset and graphics,but it includes another "BLENDE" - the piece of alloy with that you fix the cooling-unit on your board! so be patient and wait for the next two weeks! I hope I could help you! my english is not perfect but I think one can understand the contense! ;D
Markipuh
AMD Barton 2500+ @ AC-Wakü mit Cuplex v1.2 2x512 MB Infineon DDR PC400 CL3 im DC-Mode ABIT NF7-S Rev 2.0 @ Twinplex NB v1.2 ASUS V9950 FX5900 128MB @ Twinplex GK v1.2 CS601 mit APE240 und AI an Eheim1046 im MU-Käfig Samsung SP1614C 160GB Seagate Barracuda V 120GB
superhero
Re: Typ1 or Typ2?
Donnerstag, 29. Mai 2003, 14:18
If you don't want to wait any longer, you can attach the twinplex (this is the cooler which can be used for your northbridge) with thermally conductive adhesive (or whatever it is called). This is not a perfect solution, but as I said, you don't have to wait. ;)
adwhitworth
Re: Typ1 or Typ2?
Donnerstag, 29. Mai 2003, 15:51
Ok thx for the help. I have asked my Distributor to get a Type 1 for now.
Gerhard12
Re: Typ1 or Typ2?
Donnerstag, 29. Mai 2003, 17:20
As far as I can see that on the pictures of the Asus Board,it looks to be most likely the same fittings than on the Abit Canterwood Board.Therefore the twinplex CP4-Typ 1 should fit,because I´m using it on the MSI Neo and on the Abit Board and ist works out pretty good
AMD XP 1600+ IWILL XP 333 256 MB PC 3000 OCZ Idle:40°C CPUBURN: 47°C GF 3 TI 200 Gainward 235/535 2 x Maxtor 40 GB Raid 0 1 x Maxtor 40 GB Backup DVD Toshiba 1502 Traxdata 16/40 Lian Li 65
adwhitworth
Re: Typ1 or Typ2?
Donnerstag, 29. Mai 2003, 17:46
That's great ;D The perfect answer.
Sorry for the poor German ::)
