• 12.11.2026, 19:40
Mr_modnaR
Pump opinion wanted!!
Montag, 2. Mai 2005, 17:32
Hi all,
in relation to my ridiculous epia MII watercooling project, has any one used a Timmer Coolpump Typ 700 12V DC (Art.-Nr.41006)?
is it noisy?
what connections (electrical and hose connections) does it use?
cos i'm going for quietness as well as smallness (is that a word?) with this one  ;D
tia
RickCain
Re: Pump opinion wanted!!
Dienstag, 3. Mai 2005, 05:28
I have this pump and was not impressed by the flow it created. I will be giving it another run soon and will let you know.
Mr_modnaR
Dienstag, 3. Mai 2005, 16:33
Great, cheers!
as i said, i'll be using it to cool a via c3 cpu with a twinplex (that and an evo 120 is all it has to push water thru), so the flow doesn't have to be mind blowing ;D, i was more worried about the noise it may make.
thanks
RickCain
Mittwoch, 4. Mai 2005, 03:16
From what I remember this pump was on the quite side, which is good.
Mr_modnaR
Mittwoch, 4. Mai 2005, 16:18
excellent, many thanks for your help :D
