• 02.10.2026, 21:22
AM2 mounting / cooler for 7600/7800GS
Freitag, 12. Mai 2006, 18:56
Within the next 14 days aquacomputer will release new socket AM2 mountings for all CPU cooling blocks (cuplex, cuplex pro, cuplex xt, cuplex evo). If you already own one of these coolers you can easily exchange the mounting.
The new mountings are downwards compatible and can be used with the socket 939/940/754.
A first graphic:
Also a new aquagraFX block is coming soon to cool down 7600/7800GS graphic cards.
edboswell
Re: AM2 mounting / cooler for 7600/7800GS
Sonntag, 14. Mai 2006, 15:44
nice high res. pic you have there :P
bradmax57
Donnerstag, 22. Juni 2006, 02:06
Any news on this item yet?
Oxize
Donnerstag, 13. Juli 2006, 20:08
Few more weeks they said for the Am2 mounting holders.
Ich bin ein Tukker :)
Oxize
Donnerstag, 20. Juli 2006, 19:13
GoGo Development ;D
Wanna buy soon ;)
JaR
Mittwoch, 26. Juli 2006, 15:46
Ah, it's available now.
But who designed this?? I liked the Cuplex XT...
badger badger badger ...
richard.docksey
Mittwoch, 16. August 2006, 14:56
Hi.
I recently bought a cuplex xt cooler with the new socket am2 mounting, but had some trouble attaching it to my (am2) motherboard (http://tinyurl.com/lou2m).
it came with four long screws which don't fit the motherboard backplate holes, and two backplate adapter bolts which do - but the problem is that there are only two of them, and I have four holes...
at the moment I've mounted the cooler by using the adapter bolts "crosswise" across the block - which seems less than ideal...
has anybody else had a similar issue? have I bought the wrong cooler for my mainboard?
any help, greatly appreciated.
Richard.
JaR
Donnerstag, 17. August 2006, 04:31
Afaik you should remove the backplate and use the screws as depicted here.
richard.docksey
Donnerstag, 17. August 2006, 12:43
damn. thanks for the info - I'd thought about taking off the backplate but it seemed pretty well attached.
I'll take another look. still a little confused by the adapter bolts though - as there are only two of them.
cheers.
R.
JaR
Freitag, 18. August 2006, 05:31
Those bolts are for the A64. Though it would be a nice thing to include 4 bolts now, since yanking off backplates does kinda suck.
pharao
Freitag, 18. August 2006, 11:02
Zitat von »richard.docksey«
Hi.
Richard.
I'd try to send an email to support@aquacomputer.de, I think they'll get you two more screws quickly, maybe for a little fee...
richard.docksey
Freitag, 18. August 2006, 13:07
thanks for the replies - I only posted here as the support guys ignored my two emails :)
I'll see if I can source two more backplate adapter bolts from someplace,
cheers,
Richard.
pharao
Freitag, 18. August 2006, 13:19
write some more! ;D
