• 10.10.2026, 06:20
Russell
Sugestions and help setting up Powerajust ultra with D5 pump
Dienstag, 29. März 2011, 11:48
Does anny one know how to setup Power ajust ultra with D5 pump
There are so many parameters not certain what to setup
Have a single loop sustem with 4 water temp sensors "cpu in ,mem water block in,chipset out , 1 x flow sensor
Was hoping to slow pump down when temps low and speed the flow up when things heated up.
Anny sugestions on what paramirurs to set and what I could do that is usefull with all of it conected to a aquero5
I have a seporate power ajust ultra for my heat exchainger and a coupl of air sensors for that lot.
creekin
Dienstag, 29. März 2011, 17:40
flow doesn't have much affect on temp
better to set your pump at a good flow according to your flow sensor and adjust fan speed as needed :thumbup:
