• 23.11.2026, 00:02
TYPOlight error
An error occurred while executing this script!
  1. If you are a TYPOlight user, contact the administrator of your website.
  2. Open file system/logs/error.log and search for a corresponding entry.
  3. Open file system/config/localconfig.php and add the following line:
    $GLOBALS['TL_CONFIG']['displayErrors'] = true;
  4. Visit the TYPOlight project page or search the TYPOlight forum.
downtownhippie
fountain from above?
Dienstag, 19. April 2016, 16:45
it looks like it, but I wanted to confirm - can the fountain affect of the aqualias reservoir be achieved by using the top (center) inlet to the res, instead of the one at the base of the res that goes up the center pipe?
Donnerstag, 21. April 2016, 14:39
Yes, would work. Since the water would be blocked at the center port it can only escape at the top through the holes around the rod. There is a small drilled hole between the center port and the top of the base. It acts as bypass to control the flow rate for the effect. Maybe you have to close it (headless screw is included) to get a better effect or maybe also let it open if the pump is very powerful because otherwise you might decrease the general flow rate.
downtownhippie
Samstag, 23. April 2016, 15:36
thanks - I hope to get to leak testing this weekend, should see how it works soon!!!
nick29
Samstag, 28. Mai 2016, 03:14
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »nick29« (2. Juni 2016, 19:41)
