Sie sind nicht angemeldet.
$GLOBALS['TL_CONFIG']['displayErrors'] = true;
sproggit
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »sproggit« (21. Februar 2021, 17:17)
girion
Total overkill!3 Dedicated Cooling Loops:-
Silicon electronics is designed to withstand around 50C, anything more than that will reduce the life span of the electronics. From that respect you have already achieved the goal.Under load, my CPU might get as hot as 50-55 Centigrade [when I run Prime95, I can see some of the individual cores are peaking as high as 110 Centigrade (according to CPUID HWMonitor), but overall the coolant stays around 45 centigrade]
Also under load, my GPU#1 might get up to 49-50 Centigrade with the Noctua fans at 500-550rpm... especially when I'm playing a single-GPU game like Horizon:Zero Dawn...
It seems to me like you aren't really prepared to believe the statement that pump speed doesn't matter.
I'm also completely unsure how to set or tune the 3 D5 Pumps ... no idea what a sensible lower edge rpm speed should be, or how quickly I should boost flow as temperatures rise. Pumps seem very noisy when they crank to higher speeds...
sproggit
cptninc
sproggit
sproggit
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Bartdude« (22. Februar 2021, 08:15)
sproggit
) It all really depends on what your aim is, quiet PC or keeping your components as cool as can be or somewhere in the middle? Most aim to achieve a Delta T (difference between water temp and ambient) somewhere at 10c or below. Can you tell me the orientation of your fans, are they push or pull? Looks like you are blowing warm air out rather than bringing cool air in unless your fans are in pull. Rads work best with fans in push unless it's push/pull and rads like cold air. I can't say what your flow is doing but I can say that the hard 90's directly off the pumps will hit the flow dramatically and should be avoided if it can be. What does it read on the pump/s? Optimally you want somewhere in the region of 0.5 GPM - 1 GPM, anything lower is going to give sub par performance. Overclock where you posted your pic has a lot of people who will tell you the same as I have. There is a wealth of knowledge there. (I'm also a member
cptninc
sproggit
girion
sproggit
girion
In my view you are touching one one of the key elements of building a truly silent machine (as in 0 dB). That is what I learned from building passive machines, at least.But if I could get rid of the PSU noise... then this monster will be inaudible for 90% of the time...
