Sie sind nicht angemeldet.
anub1s21
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »anub1s21« (29. Oktober 2026, 05:28)
anub1s21
Take some screenshots where you can see in Aquasuite that the fans aren't working as they should.
In your current screenshot, the fans are doing exactly what's set— 0%.
I dont see any screenshot for this settings.
SL-INF's these are also on 0% but spinning at 2100rpm
anub1s21
anub1s21
Are the fans connected directly to the Octo, or do you have any cables, adapters, or splitters in between?
he SL-inf's are daisy chained / directly connected to the octo
anub1s21
as soon as the device powers on...aka startup behaviour, it is not following the profile, upon starting my pc i'd say there's a 40% chance of aquasuite at some point pushing the profile through (as i sometimes just go screw it CBA and grab a coffee first and magically when i come back...it applied the profile...or the octo decided now is the time to do what the profile says). other times i see the temp threshold has been reachted, the minimum and fallback fanspeed are suggestions at best, and 2 fan's with 0% output are spinning flat out.
OCTO Firmware 1021:
QUADRO Firmware 1034:
- Bugfix: Curve controller startup behavior
Dieser Beitrag wurde bereits 8 mal editiert, zuletzt von »anub1s21« (4. November 2026, 15:13)
das1985
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »das1985« (8. November 2026, 07:24)
