• 05.10.2026, 02:02
TYPOlight error
An error occurred while executing this script!
  1. If you are a TYPOlight user, contact the administrator of your website.
  2. Open file system/logs/error.log and search for a corresponding entry.
  3. Open file system/config/localconfig.php and add the following line:
    $GLOBALS['TL_CONFIG']['displayErrors'] = true;
  4. Visit the TYPOlight project page or search the TYPOlight forum.
SNIFFER
I think I have a small leak
Freitag, 20. Oktober 2006, 13:43
Howdy all, the level of water in the aquatube is definitely going down. This is being backed up by the tubemeter which did read 90% about 3 weeks ago, it has now dropped to 80%.
If there is a leak it is very small and so far undetectable. There is also no evidence of water marks anywhere I can visually see at the moment, back up by the dust on the system.
Does anyone have any tips on leak testing. I have quite alot of blocks on my system fitted into a small space.
Also its hard to say if the leak happens when the system is running, not running or both.
When it is running its hard to stick your hand in there to feel, with all thoes components about.
SNIFFY
A_L
Re: I think I have a small leak
Freitag, 20. Oktober 2006, 18:56
you can detect any LEAK or stains from leaking by adding UV additves into your coolant; then under dark surounding, search the parts and the bottom of the case. Then you might able to find them  ;D
SNIFFER
Freitag, 20. Oktober 2006, 19:27
Yeah a good idea indeed
