• 02.10.2026, 13:54
TYPOlight error
An error occurred while executing this script!
  1. If you are a TYPOlight user, contact the administrator of your website.
  2. Open file system/logs/error.log and search for a corresponding entry.
  3. Open file system/config/localconfig.php and add the following line:
    $GLOBALS['TL_CONFIG']['displayErrors'] = true;
  4. Visit the TYPOlight project page or search the TYPOlight forum.
BigFloppyLlama
A question on the aquatube
Freitag, 11. April 2003, 09:31
I'm ready to order it from http://www.wizarddesigns.co.uk/ but I have one more question. The barbs this site displays says that they are 10mm (roughly 3/8 inches) female barbs. I have no experience how these barbs work (all mine are male barbs). Anyways, I run 1/2" tubing through all of my loop, and I would need to buy these tube converters for it to work. Then I would buy this tubing to put over the 3/8" barb going to the reservoir. Is this all correct, or am I missing something vital here? Thanks, and if possible could anyone explain the female barb thing. Thanks again everyone.
SirCus
Re: A question on the aquatube
Freitag, 11. April 2003, 10:31
Hi Llama,
Im not 100% sure about inch and mm, but it should work I guess.
regarding the female barbs, I think you mean Plug'n'Cool adapters. If so, just put the tubings into the barbs, thats it. No screws, just press the tubing forcefully(!) into the female barb.
If it is leaky (test it outside your pc before!) you need to press it more deeper into the barb.
(gott, was heisst denn "gegen einen widerstand drücken" in english?? )
hope that helps
Cus
r1ppch3n
Freitag, 11. April 2003, 10:43
i really wouldn't recommend doing that!
you will need quite stiff hoses with exact 10mm outer diameter for this plugs, this system is quite different (and imo better!) from the one you are using...
the best solution for you would probably be to simply exchange the plugs with ones that fit to your system (g1/8'' for 1/2'' tubing)
ps: please excuse my bad english ;)
Ancalagon
Freitag, 11. April 2003, 14:01
The AquaTube is available with either 8mm push-in fittings or 10mm hose barbs (at Wizard Designs, that is). The barbs displayed on their website are the 8mm push-in fittings (called "Plug&Cool") which are absolutely incompatible to your male barbs, even if the diameter would be the same. Plug&Cool seals at the outside of the hose so you need very stiff hoses (made of PUR) like Rippchen already mentioned but with 8mm outer diameter.
I aree with Rippchens suggestions to exchange the fittings for 1/2" male barbs with G1/8" screw thread, this would probably the neatest solution. Don't ask me where to get those barbs, though... ;)
Of course you can use the reducing couplings, too. Be sure to order the AquaTube with 10mm barbs if you want to do this. 3/8" are 9,5 mm so this may be a tight fit but you shouldn't have any problems with leakage. :)
-- Hoban Washburn
BigFloppyLlama
Samstag, 12. April 2003, 02:19
Yes, I was planning on getting the 10mm barbs. On their site, it says "Available with angled/swivelling or straight 8mm push-in fittings or straight 10mm hose barbs." I'm assuming the 8m push in fittings are the female types (shown in the pictures), and the 10mm barbs look like this:
Again, thanks everyone and sorry for not posting in german, but you know how we americans are ;)
aqua-freak
Samstag, 12. April 2003, 02:31
;D
allright boy, it´s also cool to have an american in our forum ;)
as far as i know you are the first american here. ;D
----> i´m only joking. i hope you won´t missunderstand this ;)
BigFloppyLlama
Samstag, 12. April 2003, 02:44
Zitat von »Dani«
;D
How dare you! No really, any nationalistic feelings I have ever had are long gone. Only reason I'm here is.. well I can't think of one other than I'm too young to move out, but I have considered the UK after I graduate.
thore
Samstag, 12. April 2003, 03:46
don't flee - strike against the empire ;D
Samstag, 12. April 2003, 17:44
Zitat von »Dani«
...as far as i know you are the first american here.
No.
There are two or three other American in this Forum.
