• 19.11.2026, 14:10
hrmes
Aquaero 5 XT periodic connection loss
Dienstag, 17. Juli 2012, 21:41
One problem that I'm having with AQ5 is that it loses connection with the Aquastream XT pump via Aquabus 2 or 3 times every day. The connection loss can last from 1 to about 30 seconds each time and this triggers an alarm as I have programmed it to do. During this connection loss the Aquastream XT pump is still accessible with the old Aquasuite software normally.
The Aquastream firmware is 1017 and Aquaero 5 XT firmware is 1024, and it's hardware version is 5600. Does this look like a firmware issue ?
Mittwoch, 18. Juli 2012, 08:57
A new aquasuite version should be available today. It will also contain a massive update/change for the aquabus interface which should solve that problem.
