• 12.11.2026, 17:14
zerophase
Using temp sensor connected to mps flow 400 with aquaero controller.
Sonntag, 8. April 2018, 05:21
Hey I'm just checking if it's possible to use a temp sensor connected to the mps flow 400 with a fan controller on the Aquaero 6? I can't seem to find that temp sensor in the list of inputs
Freitag, 13. April 2018, 09:31
Maybe you are looking at the wrong menu. If the flow sensor is only connected via USB, you have to set up a software sensor in the aquaero to be able to access the external temperature sensor of the flow sensor.
