• 13.10.2026, 06:55
Railgun
VISION terminal with active back plate LEAK!
Dienstag, 6. August 2019, 20:32
AC folks.
What was the cause for the redesign/lengthy delay for the title part?
I'm finally getting around to installing my card and to my dismay, the thing leaks like a sieve where that part meets the main block. I'm about to dismantle it for the THIRD time to see if I can finagle it to work. The gasket is pretty much too thin really. Is this a known issue you're working through?
I'd highly recommend a larger gasket there. In my several years of WCing, something like this has never been an issue. Hopefully this isn't par for the course for these new products.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Railgun« (6. August 2019, 20:45)
Mittwoch, 7. August 2019, 17:52
The o-ring groove was milled to deep at some of the parts. If you have an issue with the terminal please write a mail to our support.
