• 20.11.2026, 18:49
Lucky75
How I can manage Aquero for FAN and Pump settings
Mittwoch, 26. August 2020, 10:02
Hello guys,
I still do not have software installed. It is possible with remote control to manage pumps and fans to be most quieted and performance.
How to configure profiles ?
Mittwoch, 26. August 2020, 10:53
Don't have a remote control, but I'm pretty sure you can use it to switch profiles.
The AE allows 4 profiles.
For your purposes you can create one with your performance settings and another with your quieted.
You can also set alarms so that they switch profiles. (e.g. if water temperature in quieted over 45 ° C go to performance)
