• 22.11.2026, 07:51
Ralph_IT
Updated to Aquasuite X.35 -> All Virtual Sensors are gone!
Dienstag, 19. Januar 2021, 19:07
I've just updated this morning to Aquasuite and all of a sudden all my virtual sensors are gone. All of them.
I did not do a "clean" install, just an install, and it worked before.
Strangely, the virtual sensors are shown in the [Aquearo->Sensors] tabs.
Also, I tried to configure them again but the Playground don't show ANY value for ANY sensor.
How can I retrieve my sensors?
Dienstag, 19. Januar 2021, 19:08
Stop and start the aquasuite service and reboot the system.
Ralph_IT
Dienstag, 19. Januar 2021, 19:29
Well, that worked, but I'm in deep sh*t right now.
I updated the firmware for the Aquaero and all the controllers are those of the default settings.
Time to rename and redo them all.
BTW: I think it would be a nice idea to disable the "update firmware" button if there is not update availablem, just for the few of us that cannot troubleshoot an issue without getting into more trouble. :D
»Ralph_IT« hat folgende Datei angehängt:
Dienstag, 19. Januar 2021, 19:34
You can use the backup from your last settings in the system tab (aquaero). When you start a update the aquasuite save all your settings to a file.
Ralph_IT
Dienstag, 19. Januar 2021, 19:44
Thanks, Sebastian!
That save me a ton of time! :thumbsup:
