• 30.09.2026, 07:58
WhiskeyOmega
D5 Next Curve Controller Not at correct level on X36
Freitag, 12. Februar 2021, 22:46
Not sure why but the pump seems to running at a higher power than I have asked of it ?
If I set it to curve controller on the pump itself its fine but set it in Aquasuite it seems to be higher.
Freitag, 12. Februar 2021, 23:05
The controller ouput is scaled to the min and max pump settings. (scroll down)
WhiskeyOmega
Samstag, 13. Februar 2021, 14:45
Ok, It was ignoring the min max unless i selected another mode and went back to curve controller. Works now
