• 02.10.2026, 09:45
daywpc
Need advice Please and maybe an explanation
Dienstag, 4. Mai 2021, 20:41
I have brought the following (see below) and I am just wondering if I brought the right amount of Splitty4 and the correct fan controller OCTO for everything to be connected RGB etc or do I need more cables etc?
If somebody could please give me some input on how it all would
be connected and what else I need if anything that be great.
1 x OCTO
1 x Aquacomputer HUBBY7 internal USB 2.0 Hub
4 x Splitty4
9 Corsair ML120 fans RGB
Aquacomputer aquaero 6 LT USB Fan-Controller
ULTITUBE D5 200 PRO expansion tank with D5 NEXT pump RGB
Aquacomputer VISION RGBpx connection terminal for kryographics
Thanks Day
Hufeisen
Mittwoch, 5. Mai 2021, 17:43
Connect the Octo, the D5 Next and the Vision Module with USB to the Hubby7.
Then connect the Hubby7 to your Motherboard.
Connect the Splitty4 in series, and then to the Octo RGBpx output.
Octo RGBpx Output --> RGBpx Cable --> Splitty4 --> RGBpx Cable --> Splitty4 --> RGBpx Cable --> Splitty4.
Then connect the Fans to the Splitty4's.
daywpc
Mittwoch, 5. Mai 2021, 19:09
Thanks Hufeisen.... perfect and much appreciated :thumbsup: :thumbsup:
