• 02.10.2026, 09:14
Virtual sensor anomaly?
Donnerstag, 17. März 2022, 21:32
I imported two virtual sensors and am experiencing something unusual.
I recorded a video, but the sound did not come across properly, so I added some text below to help follow what I am trying to show.
I attached the two virtual sensors below, and a link to the VIDEO
  • Import Virtual Software Sensor 'fan 1 control' (f1)
  • all values are missing (should sources be saved?)
  • import Virtual Software Sensor 'ambient/coolant Δt' (Δt)
  • the sensor looks operational
  • Δt is the source for f1, left column, 2nd box from the bottom
  • switching to f1, it displays the correct value in the main sensor box, but none of the value are shown in the virtual sensor, and no value should be shown in the main box.
  • I edit the upper left box (low minute) in f1, and all the values appear in the virtual sensor
  • switching to Δt, the source is gone, and the fall back value of 7 shows in the main box, but nothing in the sensor
  • when I edit the settings here and just accept, it all goes good but f1 goes back to fail
»InfoSeeker« hat folgende Datei angehängt:
Donnerstag, 17. März 2022, 23:14
restart the aquasuite or your pc after an import your sensors.
Freitag, 18. März 2022, 00:42
Yeah the audio in your video has definitely been Donald Ducked. I have a USB webcam that does this on occasion. Its so nice when I call into a business meeting and everyone starts laughing when I talk. I think its a sample rate mismatch that causes this. Anyway, It was pretty hard to follow what you were doing without the audio but I think I got the idea. Please do post if restarting AQS after importing the sensors solves the issue.
Freitag, 18. März 2022, 02:50
Here is a VIDEO that hopefully works.
Firefox was having a corruption issue, but MS Edge played it OK
I will import the five virtual sensors & restart the aquasuite next.
Freitag, 18. März 2022, 03:39
I imported the 5 virtual sensors, closed the aquasuite and restarted the aquasuite - VIDEO
Then I reinstalled the aquasuite, not to the New level VIDEO
Freitag, 18. März 2022, 04:35
Rebuilt the coolant/ambient Δt sensor and fan 1 controller, then copied and modified the remaining 3 controllers. All good,
