• 05.10.2026, 08:16
JohnHind
Show the time in Aquasuite Overview Page
Dienstag, 5. April 2022, 13:09
I tried to set up a digital clock display in a custom overview page. I set two simple 'single value' fields one bound to hours and one to minutes. Trouble is when the values are less than 10, the display drops to single digit which looks unnatural for a clock display. There does not seem to be any setting for 'significant digits' which could be set to two so '2' would show as '02' etc. with a leading zero.
Is there any way to achieve this? If not, could I request a 'Number of significant digits' setting be added to the Display settings alongside the existing 'Number of decimal places' setting? This could be a minimum, so if the number was too big, more digits would be shown and a setting of '0' or '1' would give the current behavior.
pine_kz
Similar to curve controller?
Dienstag, 5. April 2022, 20:30
The each ones digit of power percentage and temperature is missing in Curve controller.
But the worst phenomenon is that this software freezes as the time format is "hour:minute:second" and not enough display space.
So I have to wait the time format will change to "minute:second" in overview page.
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »pine_kz« (5. April 2022, 21:00)
