• 10.10.2026, 06:19
Makse
Fan curve mystery Octo
Mittwoch, 31. Januar 2024, 21:39
Hello
I just got an Octo, and installed Aquasuite.
Started to play around with fan curves. But something is very wrong.
Please see attached pictures.
If I set the Fan 1 curve to automatic (Or set it manually) and then shift to Fan 2, and change/touch just one point, the Fan 1 curve gets totaly messed up. (Picture 3)
Whats the problem?
Thank you in advance.
»Makse« hat folgende Bilder angehängt:
Donnerstag, 1. Februar 2024, 07:25
Click Automatic Settings to set up the curve and move the slider.
Makse
Donnerstag, 1. Februar 2024, 12:28
Hello Sebastian
That is exactly what i did in picture 1. Then I chose Fan 2 (Picture 2), made a small change and jumped back to Fan1 (Picture 3)
Donnerstag, 1. Februar 2024, 13:07
This is a display error. If this occurs, you must click on another fan and then switch back again.
In the next aquadsuite update this issue is fixed.
Makse
Donnerstag, 1. Februar 2024, 17:17
Yes, I finaly figured it out late last night.
Thank you for your support.
