• 12.11.2026, 19:39
MateuszT
Problem installing Aquasuite 2.7.0.0
Montag, 14. Juli 2025, 08:23
Hello,
I recently bought OCTO and connect it to the PC, but when I try to install aquasuite 2.7.0.0 I got empty screen with language choose.
Can anyone advice what could be the problem ?
Montag, 14. Juli 2025, 08:52
Your device should appear in the window with a version selection of which aquasuite version you can install.
There may be a problem with your internet connection.
MateuszT
Montag, 14. Juli 2025, 15:53
I've restarted the PC and re-plug OCTO USB cable and it went through installation. Thank You.
