• 10.10.2026, 05:15
new: aquagrafx G200 for GTX280 graphics cards
Donnerstag, 19. Juni 2008, 01:21
Two days after the start of the new Nvidia G200 generation we can present you the aquagrafx G200 which was already announced a while ago.
The cooler is produced from highly purified electrolysis copper and provides an extremely high cooling capacity. Due to the up to 20mm broad channles inside the block it has an extremely low flow resistance.
The copper plate of the cooler is approx. 8 mm strong and weighs approx. 660 g completely. It is CNC milled from a solid raw part of almost 2.2 kg of copper.
The GPU area is covered by an optimized cooling surface which offers around. 25% more surface than the one used until now.
The GPU, video chip, RAMs and voltage regulators are covered by the block. Altogether, 17 components on this card are cooled by the aquagrafx G200.
The connections are G 1/4". The price will amount to EUR 94.90. The delivery starts in the middle of next week but you can already preorder.
Here the pictures:
MUFFDIVER
Re: new: aquagrafx G200 for GTX280 graphics cards
Donnerstag, 19. Juni 2008, 17:28
I had a G200 many years ago :P
Donnerstag, 19. Juni 2008, 18:02
Hehe, Matrox... ;D
MUFFDIVER
Freitag, 20. Juni 2008, 02:34
hehe and cheers shoggy all my parts are here just need a 8800 GTX cooler and im complete but going to wait out as im unsure of my new add in the UK.
Gratz to germany for winning tonight!
Does the 8800 GTX U cooler have a plexi version or is it just the one thats listed?
Donnerstag, 26. Juni 2008, 19:16
The inside:
@MUFFDIVER: it's not avilable with a plexi-top.
MUFFDIVER
Dienstag, 1. Juli 2008, 21:28
ooooo shiney!!!
elanee
Donnerstag, 10. Juli 2008, 03:20
can this block be used with 3 way sli if i use short bars like http://www.aqua-pcs.co.uk/ek-g14-to-12-s…-barb-839-p.asp
JAROD
Freitag, 22. August 2008, 01:27
I question about other side of the card - memory cooling. Aquatuning will made something in this case ?
[right]Intel QX9650 Asus Rampage Formula 0408 EVGA 8800Ultra 4GB Apogee GDGT Samsung 500GB, Segate Barracuda 500GB All cooled by LC[/right]
Freitag, 22. August 2008, 01:47
Aquatuning is a German reseller of watercooling stuff and not a manufacturer ;)
Well, we will not produce anything for the other site of the card.
Jag
Freitag, 22. August 2008, 21:02
How about some "making of" videos?
zugzwang
Dienstag, 9. September 2008, 22:02
has any1 got these blocks in a loop with CPU + 2 x GTX280 in SLI ?
how does it perform?
elanee
Samstag, 13. September 2008, 13:37
got cpu nb/sb/mofset and gpus in same loop and it cools realy good 35-40 idle 45-50 load
zugzwang
Samstag, 13. September 2008, 19:59
Are your AquagraFX g/card waterblocks in parallel?
I don't understand how the Twin-connect works.
phinix
Samstag, 18. Oktober 2008, 21:32
Sweeet! Can you please show some more pictures of your Aqua GTX blocks in your rig?
What radiators do you use in this singl loop? What CPU?
elanee
Dienstag, 21. Oktober 2008, 02:57
will post some pics later ... working on the project atm so cant leak any pics.
used to have a 3x3 120 mm radiator from ac but now im using a trippe + a double swiftech radiators that i put inside the case ... having one big rad wasnt that practical and didnt cool as well as i though i would. i promise some pics when im finished with it :)
phinix
Sonntag, 26. Oktober 2008, 02:47
...and???!!!:))
Show some pictures !!!!:)
phinix
Montag, 10. November 2008, 20:51
Is there anyone else using this block here on this forum???
elanee
Dienstag, 11. November 2008, 00:20
sry for the delay
some pics here:
http://img143.imageshack.us/my.php?image=dsc0356pz4.jpg
http://img355.imageshack.us/img355/7527/06092008610fj5.jpg
http://img119.imageshack.us/img119/9027/03092008604jw6.jpg
http://img165.imageshack.us/my.php?image=03092008599be2.jpg
and allmost like i have it today
http://img371.imageshack.us/img371/8835/dsc0377me2.jpg
and this one i took just now
http://img514.imageshack.us/img514/93/dsc3375kq7.jpg
phinix
Dienstag, 11. November 2008, 21:41
Zitat von »elanee«
sry for the delay
some pics here:
WOW! These blocks are soo sexy:)
Can you explain how does taht SLI connector work cause it looks like it moved water through both blocks in a time (?)
Can I see pics of your radiators too? - the whole sisytem please:)
elanee
Freitag, 14. November 2008, 02:28
well there are several ways to connect those block .. you can either connect them serial or paralell it up to you realy ... i connected them like this because its not realy any temp differents .. some ppl claim that the flow in one of the blocks might stop and overheat but i guess if you have a powerful enough pump it wont happen.
if you want more pictures you can allways take a look at my worklog ( its in norwegian ) but you can just watch the pictures also:D
http://www.diskusjon.no/index.php?showtopic=1033497&hl=
