• 17.11.2026, 18:49
Top_Nurse
Aquastream Warranty issue
Montag, 2. Mai 2005, 08:55
If I cut back that gigantic power cord coming out of the Aquastream am I going to void my warranty? I'm using it with an Aquaero in an Aquabay AT and it only needs to be about 150 mm long at the most.
Jessica
Re: Aquastream Warranty issue
Montag, 2. Mai 2005, 16:07
I would assume you would void your warranty however i dare say it would be down to the discretion of the retailer you buy it from. Check with them first.
Top_Nurse
Dienstag, 3. Mai 2005, 00:55
Thanks Jessica :) I checked with my dealer here in the states and he said it wasn't a problem as far as he was concerned in my particular instance. However, I wouldn't want anyone to draw a conclusion that anyone else can do this. Some people might hook it up incorrectly and let the magic smoke out. :'(
