• 20.11.2026, 13:33
Announcement: twinplex pro SLI-Typ 1 (new Photos)
Donnerstag, 13. Oktober 2005, 18:26
Based on the Twinplex Pro a new SLI-version for nForce 4 boards will be available within the next week.
The new top will also allow the installation on the Lanparty board from DFI.
edboswell
Re: Announcement: twinplex pro SLI-Typ 1
Donnerstag, 13. Oktober 2005, 20:06
nice ;D
Ze@lot
Donnerstag, 13. Oktober 2005, 20:59
looks great ;D i take it there bore holes though the plexi onto the copper ? also as this is type 1, are there more versions planned ?
thanks for the update shoggy 8)
Nitrix
Donnerstag, 13. Oktober 2005, 21:12
That's great news.....im doing the water cooling for a friend who has a lan party board next week.....lol!
thanks for taking the time to put the update in the english forum!
Beun
Donnerstag, 13. Oktober 2005, 22:22
Witch version is best for the Asus A8N-SLI, this one?
Hummerman
Donnerstag, 13. Oktober 2005, 22:50
The normal Twinplex or Twinplex PRO.
Beun
Freitag, 14. Oktober 2005, 01:43
Yes, but I thought a special connection would be available so it wouldn't touch the capacitor on one site?
Nitrix
Freitag, 14. Oktober 2005, 01:51
if i rember correctly you can use the twinplex ATi card fitting yo get round it.... but tbh id just cut the bit off the touches...it works fine.
Top_Nurse
Freitag, 14. Oktober 2005, 02:20
If you cut the mounting plate like this it will be okay.
Mittwoch, 19. Oktober 2005, 01:29
First photos:
The twinplex is mounted on a DFI-Lanparty board.
The price of the coolingblock is 29.90 euro and should be available tomorrow.
Ze@lot
Re: Announcement: twinplex pro SLI-Typ 1 (new Phot
Mittwoch, 19. Oktober 2005, 01:40
thanks for the update shoggy ;D, so thats y it has the groove in the plexi top, so the gfx card can sit in. doohhhh ::)
Top_Nurse
Freitag, 21. Oktober 2005, 13:24
Just ordered a couple for myself and some friends. :D Hoping to have them here in the states in about a week.
Beun
Samstag, 22. Oktober 2005, 09:37
Just curious. In your topic I see you have a Asus A8N-SLI. I thought we established that it's better to use the "normal" type for this board? :)
Top_Nurse
Samstag, 22. Oktober 2005, 10:52
I'm not planning on using it on Feeding Frenzy. Got another project in the planning stages. Besides it's better to have something that you might need than not to have it at all. ;D
