• 29.09.2026, 01:12
ghostrunner
Script for Multiswitch
Freitag, 1. Dezember 2006, 18:01
I just bought an Aquaero and Multiswitch. I would like to make some script for the in/output exc.. But I am not sure how to go about it.
Do you have som example scripts or anyting like it.
By the way I think look of Aquaero and Multiswitch are awesome...
CygnusX1
Re: Script for Multiswitch
Samstag, 2. Dezember 2006, 12:29
http://www.technic3d.de/reviews/multi/sw_03.jpg
Perhaps this screenshot helps you. You have to program the scripts in VisualBasic.
ghostrunner
Samstag, 2. Dezember 2006, 13:20
Thanks....
I haven't programmed in VB before. Do you know any good guide/tutorials on the internet.
I have been programming in php exc. so the syntax isn't to strange for me but it would be cool with a guide....
*EDIT*
Do i need any specific software to make the scripts?
