• 22.11.2026, 09:25
martin
Hi.. New to Water Cooling which kit ?
Sonntag, 24. Dezember 2006, 02:05
Hi..
I have around 240 Euros to spend.. Im brand new to watercooling but I wish to purchase a complete Kit , unless for us beginers their is a better plan...
I would like to know if these http://www.aqua-computer-systeme.de/shop…94a55c2092bd57b would suit me ? if so wich one...
I want to cool a socket 939 AMD 4600x2 but Plan to go Socket 775 with a new system later.. Also plans to cool a 8800 GTX.
I have a big tower so space is no problem.. But Im unsure what I should be looking at in the way of connections etc etc
Does the complete kit come with every thing I need ? or do I have to buy alternative items ?
Thx for any info
Martin
martin
Re: Hi.. New to Water Cooling whih kit ?
Sonntag, 24. Dezember 2006, 02:06
double Post
Infiltraitor
Re: Hi.. New to Water Cooling which kit ?
Sonntag, 24. Dezember 2006, 02:47
Those kits are good as they generally cater for a range of budgets and include most of the gear you'll need.
They don't include any of the waterblocks you'll need, nor the fittings for connecting the tubing to the blocks - you'd need to add those to an order separately (which will push the price up).
martin
Sonntag, 24. Dezember 2006, 11:43
Ah ok.... Thx I assumed it was complete kit...
