• 05.10.2026, 23:13
daherik
Cover/Housing for Aquastream
Montag, 15. Januar 2007, 17:00
Im sure I have seen several pictures of systems made with the aquastream pump in a black housing/cover. However I can't see to find this item anywhere. Who is selling such a thing?
It is even metioned in the aquastream-manual, i think they called it an "fjm-housing" or something.
Does it silence as well?
Thanks in advance for the answers.
Regards,
Erik Dahl
Re: Cover/Housing for Aquastream
Montag, 15. Januar 2007, 17:20
Sorry, but the FMJ is not produced any more.
There were problems in connection with the RoHS regulations.
If you line the case with foam material, then the pump is a little more quiet.
Infiltraitor
Montag, 15. Januar 2007, 17:55
Have you mounted your Aquastream using a set of the anti-vibration mounts?
They're probably better for eliminating pump noise due to vibration - my Aquastream is pretty much inaudible.
If you have and you're still getting noise, maybe you've got air trapped in the pump?
Montag, 15. Januar 2007, 19:28
Maybe you are interested in "the Sandwich" ;D
Infiltraitor
Montag, 15. Januar 2007, 20:00
Can I have mayonnaise with that please? ;)
Very clever - ghetto pump mounts.
daherik
Dienstag, 16. Januar 2007, 13:02
I think i'll go for the sandwich ;D
Do you know what the sponge like things are called in english?
Dienstag, 16. Januar 2007, 14:23
Sponge rubber ;)
