• 14.10.2026, 02:47
Earthmonger
Temp Sensor Length matter?
Mittwoch, 28. April 2010, 11:41
Maybe it doesn't matter, but I thought I would ask anyway: Does the length of the wire impair the performance of the temperature sensors? I plan to use about 2.5m of wire between the Aquaero and my PC.
melon
Mittwoch, 28. April 2010, 11:54
Should work fine with a recalibration of the Sensors.
The Sensors are based on 10 kOhm NTC's, so 2.5m of additional Cable shouldnt be a massive change in the overall Resistance.
(Ps: man kan über treiben)
Earthmonger
Mittwoch, 28. April 2010, 12:27
Thanks for the quick reply and the useful info. :)
