• 29.11.2026, 09:55
DerMaddin
Re: wer kennt sich mit SSH aus ?
Monday, December 6th 2004, 10:42pm
also ich hab jetzt mandrake 10 drauf. hab mir mal die install durchgelesen ...... und gemerkt, dass ich n richitger linux noob bin :(
da stand irgendwas von kernel einbinden oder von ordnern, wo ich gar net kenn. ....
geht das auch vom KDE aus ?
edit: ich habs von diesen w-lan treibern ;)
hurra
Monday, December 6th 2004, 10:47pm
Tjo, da musst du halt jetzt durch. Und einfach schnell wird das wohl für dich nigs werden.
DerMaddin
Tuesday, December 7th 2004, 9:52pm
kann mir echt keiner helfen ?
hurra
Wednesday, December 8th 2004, 4:52pm
Quoted from "DerMaddin"
Wie soll man dir mit einer solchen Angabe helfen?
DerMaddin
Wednesday, December 8th 2004, 5:19pm
hmm....
perfekt wäre, wenn du diese Datei runterlädst und mir die install auf WinXP-user-Deutsch übersetzen würdest ;)
hurra
Wednesday, December 8th 2004, 5:24pm
Quoted
For 2.6:
1. Latest module-init-tools. Ok, you probably don't need the very latest, but I don't want to guess what the minimum version should be, so just make sure you have the latest.
2. Latest gcc 3.x or 2.95.x. Chances are, many many other versions also work - I'm just not supporting them.
3. 2.6.9 kernel or newer. You must have your kernel tree installed and configured for kbuild to build your module. Crypto API (CONFIG_CRYPTO) and the ARC4 cipher must be compiled in or as modules or the driver will not work.
4. Wireless tools. Latest is prefered, but having slightly older versions are very unlikely to cause problems, at least compared to potential problems with the driver itself.
5. Latest hotplug scripts. This is somewhat optional, but it makes things easier.
To install, just run make install. You can also do make, then make modules_install, which uses the kernel build system to install the modules. However, if you do it the second way, you'll need to run depmod -a manually.
DerMaddin
Wednesday, December 8th 2004, 6:26pm
Quoted from "hurra"
genau das blick ich net.
was soll ih da tun ?
hurra
Wednesday, December 8th 2004, 6:27pm
als root make install eintippen und <enter> (wenn du die ganzen sachen vorher beachtet hast)
DerMaddin
Wednesday, December 8th 2004, 6:33pm
Quoted
hab ich das, wenn ich mandrake 10.0 installiert hab ?
hurra
Wednesday, December 8th 2004, 6:42pm
Das weiß ich nicht.
Kannst du ned in deiner Paketdatenbank nachschaun. Irgendwas wo du deine installierten Pakete siehst wirst du wohl haben.
E: Und und ob du die Sachen im Kernel hast weiß ich auch ned.
DerMaddin
Wednesday, December 8th 2004, 6:44pm
ich reboote mal und schaue, kann ein paar minuten gehen...
ach ja 245467664: eiskuh bzw miranda... :)
edit:
also: ich hab was gefunden mit gcc - cpp - 3.23.2-6mdk
und denn noch kernel 2.6.3.1mdk1-1mdk1
das heisst also mein kernel ist zu alt und ich kanns vergessen ?
---warum ist der forenserver so lahm ?
hurra
Wednesday, December 8th 2004, 8:21pm
Anscheinend ist dann dein Kernel zu alt. =>Neuen runterladen und kompilieren
DerMaddin
Wednesday, December 8th 2004, 9:26pm
soso... ich glaub ich bleib bei windows...
is irgendwie doch einfacher
LaNcom
Thursday, December 9th 2004, 4:10pm
Du brauchst keinen neuen kernel, Du brauchst eine ältere Version von den WLAN Treibern (oder einen neuen kernel). Versuche mal die 20041111 oder so.
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music." -- Kristian Wilson, Nintendo, Inc, 1989.
