You are not logged in.
Quoted
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programme\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22.07.2004 17:33:44
Nero Version: 6.3.1.25 (Nero Express)
Recorder: <TEAC CD-W512EB> Version: 2.0B - HA 1 TA 0 - 6.3.1.25
Adapter driver: <nvidesm> HA 1
Drive buffer : 2976kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <PIONEER DVD-ROM DVD-106 >Version: 1.22 - HA 1 TA 1 - 6.3.1.25
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SP1213C SV10 si3112r Port 0 ID 0 DMA: Off
CdRomPeripheral : TEAC CD-W512EB 2.0B nvidesm Port 1 ID 0 DMA: Off
CdRomPeripheral : PIONEER DVD-ROM DVD-106 1.22 nvidesm Port 1 ID 1 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
TEAC CD-W512EB F: CDRom0
PIONEER DVD-ROM DVD-106 G: CDRom1
Generic DVD-ROM H: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 642MB (658424kB)
Memory in use : 37 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
22.12.2004
Audio-CD
19:03:37 #1 CDADOC -1 File Cdadoc.cpp, Line 1508
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Total size: 61:57.07
19:03:37 #2 Phase 72 File dlgbrnst.cpp, Line 1855
BURN-Proof activated
19:03:37 #3 Text 0 File Reader.cpp, Line 126
Reader running
19:03:37 #4 Text 0 File AudioCompilationImpl.cpp, Line 817
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
19:03:37 #5 Text 0 File Writer.cpp, Line 124
Writer TEAC CD-W512EB running
19:03:37 #6 Text 0 File Burncd.cpp, Line 3152
Turn on Disc-at-Once, using CD-R/RW media
19:03:37 #7 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 278631 ( 61:57.06)
19:03:37 #8 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO (enabled: CD)
19:03:37 #9 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: TEAC CD-W512EB;
CDR code: 00 97 24 16; OSJ entry from: SONY Corporation
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 18 10 (LI 97:24.16), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 00 00 (invalid)
19:03:37 #10 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
Quoted
19:03:37 #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (Def Soul 02.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 19591 (19591) = #19591/4:21.16
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19591 blocks [TEAC CD-W512EB ]
1: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 16114 (16114) = #16114/3:34.64
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16114 blocks [TEAC CD-W512EB ]
2: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 16535 (16535) = #16535/3:40.35
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16535 blocks [TEAC CD-W512EB ]
3: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 20412 (20412) = #20412/4:32.12
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20412 blocks [TEAC CD-W512EB ]
4: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 19701 (19701) = #19701/4:22.51
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19701 blocks [TEAC CD-W512EB ]
5: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 21045 (21045) = #21045/4:40.45
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21045 blocks [TEAC CD-W512EB ]
6: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 17693 (17693) = #17693/3:55.68
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17693 blocks [TEAC CD-W512EB ]
7: TRM_AUDIO_NOPRE (...)
Quoted
original disc pos #0 + 16294 (16294) = #16294/3:37.19
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16294 blocks [TEAC CD-W512EB ]
8: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 14082 (14082) = #14082/3:7.57
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14082 blocks [TEAC CD-W512EB ]
9: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 13998 (1399= #13998/3:6.48
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13998 blocks [TEAC CD-W512EB ]
10: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 17444 (17444) = #17444/3:52.44
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17444 blocks [TEAC CD-W512EB ]
11: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 16913 (16913) = #16913/3:45.38
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16913 blocks [TEAC CD-W512EB ]
12: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 17618 (1761= #17618/3:54.68
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17618 blocks [TEAC CD-W512EB ]
13: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 18929 (18929) = #18929/4:12.29
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18929 blocks [TEAC CD-W512EB ]
14: TRM_AUDIO_NOPRE (...)
original disc pos #0 + 30163 (30163) = #30163/6:42.13
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 30163 blocks [TEAC CD-W512EB ]
19:03:37 #12 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [TEAC CD-W512EB ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 15:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 46430832, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 46430832 46783632 84683760, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 84683760 85036560 123926880, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 123926880 124279680 172288704, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 172288704 172641504 218978256, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 218978256 219331056 268828896, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 268828896 269181696 310795632, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 310795632 311148432 349471920, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 349471920 349824720 382945584, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 382945584 383298384 416221680, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 416221680 416574480 457602768, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 457602768 457955568 497734944, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 497734944 498087744 539525280, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 539525280 539878080 584399088, ISRC ""
15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 584399088 584751888 655695264, ISRC ""
DAO layout:
Quoted
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x01
-150 | 1 | 0 | 0x00 | 0x21
0 | 1 | 1 | 0x00 | 0x21
19591 | 2 | 0 | 0x00 | 0x21
19741 | 2 | 1 | 0x00 | 0x21
35855 | 3 | 0 | 0x00 | 0x21
36005 | 3 | 1 | 0x00 | 0x21
52540 | 4 | 0 | 0x00 | 0x21
52690 | 4 | 1 | 0x00 | 0x21
73102 | 5 | 0 | 0x00 | 0x21
73252 | 5 | 1 | 0x00 | 0x21
92953 | 6 | 0 | 0x00 | 0x21
93103 | 6 | 1 | 0x00 | 0x21
114148 | 7 | 0 | 0x00 | 0x21
114298 | 7 | 1 | 0x00 | 0x21
131991 | 8 | 0 | 0x00 | 0x21
132141 | 8 | 1 | 0x00 | 0x21
148435 | 9 | 0 | 0x00 | 0x21
148585 | 9 | 1 | 0x00 | 0x21
162667 | 10 | 0 | 0x00 | 0x21
162817 | 10 | 1 | 0x00 | 0x21
176815 | 11 | 0 | 0x00 | 0x21
176965 | 11 | 1 | 0x00 | 0x21
194409 | 12 | 0 | 0x00 | 0x21
194559 | 12 | 1 | 0x00 | 0x21
211472 | 13 | 0 | 0x00 | 0x21
211622 | 13 | 1 | 0x00 | 0x21
229240 | 14 | 0 | 0x00 | 0x21
229390 | 14 | 1 | 0x00 | 0x21
248319 | 15 | 0 | 0x00 | 0x21
248469 | 15 | 1 | 0x00 | 0x21
278632 | lead-out | 1 | 0x00 | 0x01
19:03:37 #13 Phase 36 File dlgbrnst.cpp, Line 1855
Burn process started at 12x (1.800 KB/s)
19:03:37 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
19:03:37 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #19741
19:03:37 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #36005
19:03:37 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #52690
19:03:37 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #73252
19:03:37 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #93103
19:03:37 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #114298
19:03:37 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #132141
19:03:37 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #148585
19:03:37 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #162817
19:03:37 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #176965
19:03:37 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #194559
19:03:37 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #211622
19:03:37 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #229390
19:03:37 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #248469
19:03:37 #29 Text 0 File Mmc.cpp, Line 16038
StartDAO : CD-Text - On
19:03:37 #30 Text 0 File Mmc.cpp, Line 20660
Set BUFE: BURN-Proof -> ON
19:03:38 #31 Text 0 File Mmc.cpp, Line 16327
Quoted
CueData, Len=256
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 04 17 10
21 02 01 00 00 04 19 10
21 03 00 00 00 08 00 05
21 03 01 00 00 08 02 05
21 04 00 00 00 0b 2a 28
21 04 01 00 00 0b 2c 28
21 05 00 00 00 10 10 34
21 05 01 00 00 10 12 34
21 06 00 00 00 14 29 1c
21 06 01 00 00 14 2b 1c
21 07 00 00 00 19 17 49
21 07 01 00 00 19 19 49
21 08 00 00 00 1d 15 42
21 08 01 00 00 1d 17 42
21 09 00 00 00 21 01 0a
21 09 01 00 00 21 03 0a
21 0a 00 00 00 24 0a 43
21 0a 01 00 00 24 0c 43
21 0b 00 00 00 27 13 28
21 0b 01 00 00 27 15 28
21 0c 00 00 00 2b 0e 09
21 0c 01 00 00 2b 10 09
21 0d 00 00 00 2f 01 2f
21 0d 01 00 00 2f 03 2f
21 0e 00 00 00 32 3a 28
21 0e 01 00 00 33 00 28
21 0f 00 00 00 37 0c 45
21 0f 01 00 00 37 0e 45
01 aa 01 01 00 3d 39 07
19:04:01 #32 SCSI -500 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x06010000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0xFF 0xFF 0xD1 0xC6 0x00 0x02 0xAA 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
19:04:01 #33 CDR -500 File Writer.cpp, Line 304
SCSI command aborted
TEAC CD-W512EB\H1 T0
19:04:05 #34 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
19:04:06 #35 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
19:04:07 #36 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
19:04:07 #37 Phase 38 File dlgbrnst.cpp, Line 1855
Burn process failed at 12x (1.800 KB/s)
19:04:07 #38 Text 0 File AudioCompilationImpl.cpp, Line 828
DRM: DRM burn session terminated.
19:04:07 #39 Text 0 File AudioCompilationImpl.cpp, Line 857
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\nvidesm.sys': Ver=5.10.2600.0307 built by: WinDDK, size=20224 bytes, created 13.11.2002 08:10:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
