• 03.11.2026, 05:01
Body
Bluescreen, Ursachen?
Thursday, January 5th 2006, 2:18am
So, hab nun auch mal wieder nen Problem mit meinem PC
In letzter Zeit erscheint in ziemlich unregelmäßigen Abständen ein Bluescreen, dessen minidump wie folgt aussieht:
___________________________________________
Microsoft (R) Windows Debugger Version 6.4.0007.2
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [E:\WINDOWS\Minidump\Mini010506-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805531a0
Debug session time: Thu Jan 5 01:10:58.140 2006 (GMT+1)
System Uptime: 1 days 6:47:10.727
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
Unable to load image ALCXWDM.SYS, Win32 error 2
*** WARNING: Unable to verify timestamp for ALCXWDM.SYS
*** ERROR: Module load completed but symbols could not be loaded for ALCXWDM.SYS
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000007E, {c000001d, b9e15501, b98c386c, b98c3568}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for mssmbios.sys
*** ERROR: Module load completed but symbols could not be loaded for mssmbios.sys
Probably caused by : ALCXWDM.SYS ( ALCXWDM+13d501 )
Followup: MachineOwner
Hat hier jemand eine Ahnung, woran das liegen könnte?
Hardware:
Athlon64 3000+ (auf ~3200+ getaktet (war aber auch vorher schon))
MSI K8N Neo2 Plat. Ed.
X850 Pro von Sapphire
2*1GB Ram MDT
@re@50
Re: Bluescreen, Ursachen?
Thursday, January 5th 2006, 2:19am
http://www.google.de/search?hl=de&q=ALCX…gle-Suche&meta=
hat was mit dem onboard soundkarten treiber zu tun. welchen treiber hast du dafür drauf.
