You are not logged in.
Quoted
Warning, Don`t try to connect your equipment via the analogue outputs/inputs, as this will cause a pinknoise type of sound which is not very enjoyble to listen to. It might even damage your loudspeakers.
b) It is also possible to play the multichannel soundfile directly from your harddisc if your computer is equipped with a soundcard that has an digital output.
Quoted from "b0nez"
geht ohne probleme du brauchst aber ein digitales boxensystem:
Y0Gi [/td][/tr][/table]
Quoted
