You are not logged in.
cosmic7110
mindheat
[/CENTER] [quote author=restALCH link=board=4;num=1097002433;start=45#46 date=10/06/04 um 10:31:11]scheiß drehbuch aber ne fette rollenbesetzung ;D[/quote]
Quoted from "Chewy"
und ? was nützt dir das telefonbuch ? ;D ;D ;D
Verkaufe: 2x selbstsperrende Kupplung. Für mehr Infos KM oder Mail.
Quoted from "Chefratte"
Also meiner Meinung nach ist ne Wakü für Spannungsregler sowie so überflüssig. Die dinger brauchen nicht wirklich ne Kühlung selbst wenn man übertaktet. Der einzige Grund ist das aussehen, man kühlt eben alles was zu kühlen ist z.B. Mainbord Chips und den Ram einer Grafikkarte.
Quoted
antwort von ABIT:
We have official word that the cut trace was necessary to correct a problem. Newer boards have the same fix.
The first lot of AN7 was with that trace cut; however, we have fully tested every piece of AN7 and all the functionalities are OK. Please ignore it as it in no way effects the board, infact it is a fix and needs to remain that way.
Please dont ask about what the specific problem was as I dont know and I am not going to ask for the schematics of the PCB layout and try to figure it out, just sufice it to say that all is well with that trace cut and future boards will not have it be visible.
