• 18.11.2026, 22:07
Cora-Partido
Durchflußsensor für Aquaero
Tuesday, August 10th 2004, 7:47pm
Sorry for writing in English but I don't know German.
I've bought in my country (Portugal) one flow sensor for aquaero but I didn't bought yet the cable that connects the sensor to the aquaero. It seems my shop doesn't have this cable and I need to wait some weeks till they having it.
So can someone please help me in the pinout of the sensor, until the correct cable arrives.
Many thanks
Best Regards
lucky777
Re: Durchflußsensor für Aquaero
Tuesday, August 10th 2004, 9:04pm
If you loock very carefully  ;) onto the flow-sensor you'll find the meaning of the pins ;)
But anyway, the middle pin is the signal pin, and if you hold the sensor, the cooling in/output point's at you, the left one ist the power (+4,5V to +24 V) and the right one ist the GND (-).
Hopefully this is what you wanted to know. ;D
If you'll use a different kind of flow-sensor which AC recommend ( see at onlineshop ) then I have no idea how the pins are set. But you can measure this out via the resistance of the pins !! 8)
LianLi PC V2000 ASUS A8V Deluxe AMD Athlon 64 3800+ ( 25°C - 42,3°C full load ) Gigabyte GVR80 X800PRO 480 GB HDD SAMSUNG Spinpoint's 2 GB CORSAIR PC3200 XL PRO YESICO 420 W Netzteil ...and a lot of AC-stuff
Cora-Partido
Tuesday, August 10th 2004, 9:30pm
Many Thanks!!!!
Fragom
Wednesday, August 11th 2004, 6:53pm
Quoted from "lucky777"
This handle is correct?
Thanks
Site: FaceNaWeb [img]http://seti.familie-friedrich.de/userstats.php?l=6&id=884[/img]
lucky777
Wednesday, August 11th 2004, 7:03pm
I'll check it ...... work in progress ;)
Hi-Ho ! It seems that AC has already crossed the output in the Aquaero. Very smart :o
The correct wiring is: Let the MOLEX-Plug at the AE as it is and switch the BLACK wire with the YELLOW one at the flow-sensor :-[
This is the reason why the flow sensor won't work at one of the "normal" fan connectors, anyway just switch the to wires then it's ok.
Yours
Dragonclaw
Wednesday, August 11th 2004, 7:09pm
i think theres a problem...but i did not find it yet ::)
checking too ;)
update:
lucky777 is right ;)
black and yellow have to be changed
Fragom
Wednesday, August 11th 2004, 7:24pm
They pardon but I do not understand.  But I intend that correct of this handle says which to me the linking:  Pin 1, 2 and 3 of the Aquaero goes to bind to the Pin # | + of the Flow Sensor.  Which the correct position.  Thanks.
Dragonclaw
Wednesday, August 11th 2004, 7:46pm
conector "Flow"
Pin 1 (right): signal (on the sensorpicture above: #, right)
Pin 2 (middle): +5V (sensor: +, left)
Pin 3 (left): ground (sensor -, middle)
Fragom
Wednesday, August 11th 2004, 8:21pm
Quoted from "Dragonclaw"
conector "Flow"
Pin 1 (right): signal (on the sensorpictur above: #, right)
Many Thanks.
Dragonclaw
Wednesday, August 11th 2004, 8:34pm
no problem, but wait with saying thank you until it works ;)
Fragom
Thursday, August 19th 2004, 2:40am
Sorry, but I have a problem. When installing the Flow Sensor in accordance with the project above, this does not function.
After seeing in detail the project, I think that:
Pin 1 (GND) Aquaero binds Pin T (half) Flow
Pin 2 (5V) Aquaero binds the Pin + (left) Flow
Pin 3 (rpm) Aquaero binds to the Pin # (right) Flow
Will be that thus he is correct the linking?
Thursday, August 19th 2004, 3:37am
That's the wiring on my system and it works :)
Fragom
Thursday, August 19th 2004, 6:43pm
Quoted from "Shoggy"
Ok, that connection is agreement with what above said but the Pin1 of the Aquaero is in right interest: the sequency is 3 - 2 - 1, ok?
Thursday, August 19th 2004, 7:03pm
No idea if it is numbered from left to right or the other way ;) Just look at the wiring and try this; it should work.
Dragonclaw
Thursday, August 19th 2004, 7:35pm
well, in the manual it's nubered from right to left... ::)
but soon we'll have all possible combinations tested :D
Fragom
Friday, August 20th 2004, 3:07am
Quoted from "Fragom"
ok, now already functions with this configuration! Finally!!!
jcab
Tuesday, August 24th 2004, 2:32am
Olá Face ;D
