• 18.11.2026, 20:17
JamesDersch
Re: Linux Steuerungssoftware (aeinfo)
Monday, November 26th 2007, 3:26pm
hab's nun auch unter linux (ubuntu7.10) installiert bekommen. Und muss sagen wirklich eine schöne sache. Nur hat das webinterface erst nach einem ausschalten des rechners funktioniert ??? neustarten hatte diesbezüglich keinen effekt.
Sonst gab's aber keine probleme dank der tips von dirk1166, danke dafür.
grüße
egawrangler
Re: Linux Steuerungssoftware (aeinfo)    !UPDATE!
Thursday, November 29th 2007, 8:31pm
Es tut mir leid, aber mein Deutsch ist nicht so gut.
Just finished compiling and installing aeinfo and aquaerod on a Debian distribution (Ubuntu 7.10) ;D
If you need help installing it, let me know. I'll try to translate.
Installing this package requires several tools not installed with Ubuntu, as well as careful management of how you start the aquaerod daemon server.
I've got the script files necessary to execute aquaerod, but this is dependent on your distro.
Try to give me some details on your problems...I'll see what I can do.
composer
Re: Linux Steuerungssoftware (aeinfo) &nbsp
Friday, November 30th 2007, 10:37pm
@James:
Geht es bei Dir jetzt?
Schick mir mal ne KM mit ner ausführlichen Beschreibung -- irgendwie versteh ich das nicht ganz ??? ;-)
cheers
egawrangler
Friday, December 7th 2007, 6:42am
...Just wanted to let you know
I'm working on an English translation for the aquaerod daemon. HTML is already done, and now I'm going through the C++ code. Should be done before Christmas. 8)
-EGA
composer
Saturday, December 15th 2007, 11:43pm
Quoted from "egawrangler"
-EGA
Very nice!
Then I would integrate an automatic language selection, based on the browser's language setting (or $RC_LANG for the console tool).
Btw, the next update will primarily focus on Windows Vista
egawrangler
Monday, December 24th 2007, 7:16am
Christian -
Here's what I've got, the ENGLISH package. I updated the readme file with readme.eng and added a lot of stuff, per the user distribution. I've used the daemon on Suse, Ubuntu, Fedora, and ArchLinux. All successful, but the daemon still suffers from needing to be started last in the boot sequence (or after the user has loggend in). The C++ code, HTML, and scripts have all been updated as well. Added two scripts, one for Debian and one for Suse style distros, instructions are in the readme.eng file. Pretty comprehensive, so I'm not sure about the language selection you implied. Let me know if I can help out additionally in any way.
-John
MERRY CHRISTMAS!!! 8) 8) 8)
P.S. I just realized this forum doesn't support file attachments, so I just emailed it to you. HA!
leisetreter
aeinfo mit aquastream XT USB ultra benutzen?
Saturday, December 29th 2007, 3:22am
Hallo!
Kann man mit aeinfo eine aquastream XT USB ultra unter Linux komplett konfigurieren/kontrollieren/bedienen?
Was müsste getan werden, damit das geht?
Gibt es sonst irgend eine Chance, die aquastream XT USB ultra unter Linux zu konfigurieren/kontrollieren/bedienen, wenn kein Windows im Haus ist?
Danke für die Beantwortung der Fragen!
Servus,
Peter
Ich führe einen Windows(tm)-freien Haushalt.
composer
Re: aeinfo mit aquastream XT USB ultra benutzen?
Sunday, December 30th 2007, 1:40am
Quoted from "leisetreter"
Ja (prinzipiell). Was ich so gesehen habe ist die AS-XT wohl ein reduziertes aquaero. Die "Frei konfigurierbare Kalibierkurve" könnte allerdings etwas tricky sein.
Das Ganze ist so gesehen eigentlich überhaupt kein Thema, es fehlen im Moment nur die Informationen.
Einerseits braucht man die Product-ID (jedes USB-Gerät wird identifiziert über ein eindeutiges Vendor-/Product-ID Paar).
Andererseits braucht man den Code zur Kommunikation mit dem Gerät: beim aquaero waren das die Funktionen [tt]CreateStructureFromString[/tt] und [tt]CreateStringFromStructure[/tt] (Sebastian weis da Bescheid). Wenn wir diese Infos von Aqua-Computer bekommen steht dem Ganzen nichts mehr im Wege. Mal sehen, ich schreib ma ne Mail ;-)
...nicht ohne die obigen Infos.
At least, the deamon requires that the network subsystem is up and running, procfs/usbfs is mounted and that USB is available.
cheers
edit: Ach ja, und willkommen im Forum ;)
x-stars
Re: Linux Steuerungssoftware: aeinfo 2.4 [translat
Sunday, December 30th 2007, 9:39pm
Hm,
hab zwar schon lange kein aquaero mehr, aber hab mir gerade mal den Thread hier angeschaut. Nette Sache, könnt mir glatt überlegen meinem Server ein ae-lite zu spendieren (der hat zwar keine Wakü, aber ein paar Lüfter zum Regeln sind drin :D).
Frage: Ist/kann man den Web-Srv per User/Passwort schützen, sodass man ihn gefahrlos ins Internet lassen kann?
Außerdem wärs schön, wenn du im ersten Post vielleicht ein paar Screenshots zeigen könntest, die du dann aktualisierst, wenns in einer neuen Version anders aussieht :D.
leisetreter
Monday, December 31st 2007, 12:26am
@0xm4s6c333337: Danke für die Antwort und das Willkommen!
Pumpe leihweise reicht also nicht?
Quoted from "Grinchy"
(ein bisschen OT)
Auch wenns nicht offiziell gehen würde:
Einen nginx oder lighttpd davorhängen kann man immer.
Ich habe einen nginx an Port 443, der mein Zertifikat hält und die HTTP-Sessions verwaltet, dahinter im internen Netz gibts nur HTTP, und die verschiedenen URLs werden an die verschiedenen Dienste auf verschiedenen Rechnern und Appliances weiter"geproxied".
Da kann man dann auch so Sachen realisieren wie Baustellen-Seiten(, wenn ein Dienst konfigurationshalber down ist), Zeitschlösser (Zugriff nur tagsüber) statische Inhalte schon vorne bedienen und nicht hinten von den Webanwendungen, oder zentralisiertes Logging und Benutzerverwaltung sowie HTTP-Komprimierung (die funzt bei mir noch nicht so ganz, grade Baustelle). Und nach außen ist für alle Webgeschichten nur noch ein Port offen!
(schau mal http://wiki.codemongers.com/Main oder http://www.lighttpd.net/ und http://www.websiteoptimization.com/speed/18/)
Nur meine 2ct.
Peter
JamesDersch
Wednesday, January 16th 2008, 1:49am
ich habe einen Linux Server der die nächsten Tage ein Aquaero bekommt, dazu benutze ich seit Jahren an meinem Hauptrechner die Aquasuite.
Ich weiß aeinfo hat ein Webinterface, habe mit der software an meinem HauptPc auch schon rumgespielt nur benutze ich meistens Winxp. Meine Frage ist nun ob ich dann auch ganz komfortabel in der Suite unter XP den Linux Server mit aeinfo finden kann? Fände das sehr schick in der Suite beide Rechner überwachen zu können.
dirk1166
Sunday, January 20th 2008, 1:12pm
@0xm4s6c333337
Hast Du die benötigten Informationen bekommen um mit aeinfo die Aquastream XT steuern zu können (ohne Windows eben)?
Ist schon was in Arbeit?
gruss
Dirk
Fractal Define R3|ASRock P67 Extreme4 (UEFI-BIOS 2.10)|i5-2500K|HD 5750 passiv|Crucial M4 64 GB |Seasonic X-560 |HP ZR24w|Kyocera FS-1030D|Canon LIDE 25|Ubuntu 11.04 64Bit|wieder LuKü
composer
Sunday, January 20th 2008, 9:12pm
Quoted from "dirk1166"
Nein, ich hab bisher leider keine Antwort auf meine E-Mail bekommen. Habe die Anfrage soeben nochmal rausgeschickt.
x-stars
Sunday, January 20th 2008, 9:51pm
Quoted from "0x6c333337"
Eine Routine, die Daten ins eeprom des aquaero zu sichern habe ich bisher nicht geschrieben (d.h. vorhanden ist sie prinzipiell schon, man müsste eigentlich nur ein Flag ändern) -- man kann sich aber mit einem Kleinen Trick helfen:
Einfach am aquaero den "Menü-Knopf " drücken und dann den Menü-Punkt "Zurück zur Anzeige" wählen, und schwupps, sind die Einstellungen gesichert... ;-)
Ist das eigentlich mitlerweile drin? Könntest du es sonst an die erste Stelle der ToDo-Liste setzen - nicht alle (&me) haben ein Ae mit Display :-/
composer
Wednesday, January 23rd 2008, 1:23am
Okay, das werd ich berücksichtigen - für den Moment kann ich folgende, wirklich einfache do-it-yourself Lösung für Linux-User anbieten. Man kann den Source dahingehend ändern, sodass die Daten immer in den EEPROM-Speicher geschrieben werden.
Dazu einfach folgende Schritte durchführen:
  • Öffnen der Datei aq_rev4.h in einem Editor
  • Bis zur Zeile 813 scrollen - die sieht so aus: [tt]const TransferTypeRegister Protokol = RAM;[/tt]
  • Ändern der Zeile zu: [tt]const TransferTypeRegister Protokol = EEPROM_SAVE;[/tt]
  • Datei speichern
  • aeinfo neu kompilieren & installieren
JamesDersch
Tuesday, January 29th 2008, 1:22am
habe nun in meinem Server (ubuntu 6.10) ein aquaero installiert und aeinfo 2.4 läuft. nur geht der Webserver nicht und ich weiß nicht wo ich nach dem Fehler suchen soll. der befehl "aeinfo" geht aber in der konsole. Hatte schon mal alles auf ubuntu 7.10 zum laufen gebracht und dort ging der webserver nach einem neustart.
Ausserdem muss ich jedesmal, wenn ich aeinfo in der Konsole auslesen möchte, die Gruppen Rechte umstellen (sudo chgrp -R thefab /proc/bus/usb/) irgendwie speichert der das nicht.
composer
Wednesday, January 30th 2008, 11:14pm
Hallo James,
starte mal den aquaerod-Daemon mit dem -v switch - da kommt dann einiges an Output, den Du mir z.B. per E-Mail schicken kannst. Ich verstehe aber auch nicht ganz, was es mit dem Neustart auf sich hat.
Wegen dem sudo-Problem: Da würde ich Dir eher empfehlen den aquaerod-Daemon als Super-User auszuführen. Möglicherweise unterstützt Deine Distro auch das Setzen des Benutzers über fstab (falls usbfs verwendet wird -- nagel mich nicht fest, aber irgendwas war da). Der Grund, warum er die Rechte nicht "speichert" liegt darin, dass /proc ein virtuelles Filesystem ist (Kernelinterface).
composer
Thursday, February 7th 2008, 9:33pm
Kurze Info zur Anfrage bezüglich "aquastream XT":
Ich habe (nun doch) eine E-Mail von Sebastian erhalten, und er wird mir die nötigen Infos in absehbarer Zeit (etwa vier bis sechs Wochen) zukommen lassen. Ist also für alle Linuxer mit as xt eine Gute Nachricht ;-)
ub22
Sunday, March 2nd 2008, 10:38pm
bin seit kurzen Besitzer einer aquaero 4.00 USB für die Systemüberwachung meines Linux-Servers (auf dem Dachboden) via Fenwartung (SSH). Zur Zeit benutze ich nur die Lüftersteuerung nur um mit zwei 120-er Papstlüftern meine drei Festplatten (und nebenbei natürlich auch den Rest) zu kühlen.
Bei der Verwendung Deiner ansonsten gut funktionierenden Software sind mir folgende kleinere Probleme aufgefallen. Zunächst beim Compilieren fallen einige Warnungen bei der Stringkonvertierung auf (aehttpd.cpp:1561: warning: deprecated conversion from string constant to ‘char*’) ist zwar nicht wesentlich kann man aber einfach beheben. Auch die Textausgaben haben keine richtigen Sonderzeichen (normalerweise verwenden neuere Linux Kernel den UTF8 Zeichensatz).
Als nächstes habe ich versucht das ansonsten recht ausgetüftelte Startscript für openSUSE auch auf meiner Version 10.3 zu verwenden, was aber am falschen Pfad nach dem aufruf von "/sbin/startproc -e $AE_BIN > /dev/null" scheitert (das vorherige "cd $AE_PATH" wird ignoriert). Dadurch werden natürlich die Webseiten unter "/opt/aquaerod/htdocs/" nach der Kontaktierung mit dem Web-Server nicht gefunden (führt zu einem Fehler 404).
Ansonsten ist mir noch aufgefallen, dass "aeinfo" einen Fehler erzeugt (wird auch mit der Option "-vv" angezeigt) weshalb das Kommando zwar funktioniert aber sehr lange dauert. Nach dem Starten von "aquaerod" (ändert sich auch nach dem beenden bis zum Reboot nicht mehr) kann man "aeinfo" gar nicht mehr starten, da es zu einem Speicherzugriffsfehler kommt.
Gruß UB22
composer
Monday, March 3rd 2008, 6:35pm
Hallo ub22 und danke für Deine Anregungen.
Quoted from "ub22"
Das SUSE-Start-Skript habe ich selbst noch nicht testen können. Du kannst mir Deine Verbesserungen gerne per E-Mail zuschicken
Quoted
Ein Fehler ist das nicht (wenn Du damit die "lange Wartezeit" meinst). Dies scheint ein generelles Problem mit dem aquaero, USB und speziell Linux 2.6 zu sein. Unter Linux 2.4 gabs diese Pause nicht. Und wenn man den Daemon verwendet, geht's auch wieder ganz fix. ;-)
Quoted
Bist Du unter Linux 64-Bit?! Das Programm aeinfo versucht dann mit dem Daemon aquaerod zu kommunizieren. Ist möglicherweise ein 64-Bit Problem...
