• 29.11.2026, 08:43
Hapsbanan
aquagraFX G200 problem
Saturday, December 20th 2008, 9:32pm
Hello folks.
I seem to have a major problem with my aquagraFX G200 cooler on my Asus GTX260 TOP.
Looks like the cooler doesnt reach the GPU if i watch my temps.
In idle i get ~60c temps, and on load, it just bumps up to 115c in a few seconds and shuts down.
Anyone else having problem with this?
Any suggestions?
Regards.
//Hapsbanan
Sunday, December 21st 2008, 2:34am
I would recommend to remove the block and check if everything had proper contact.
Also a possible reason for the bad temperatures could be that the screws around the GPU are not tighten strong enough. You could tighten them a little bit more and test if it would make a difference. If so, just continue but be careful!
Hapsbanan
Sunday, December 21st 2008, 3:15pm
It only had contact to one small corner of the GPU, which resulted in massive overheating.
It was not possible to tighten the screws any more that I already did.
Sunday, December 21st 2008, 5:12pm
Mhhh, it might be also possible that your card is not 100% identical to the reference layout. We also had this problem with some HD4870 cards. They looked exactly the same but the height between the RAM and GPU was a little bit different.
Hapsbanan
Sunday, December 21st 2008, 10:27pm
This is the gfx I got:
http://asus.com/products.aspx?l1=2&l2=6&…335&modelmenu=2
Other people who got problems with this card and the aquagraFX G200 cooler?
Similar threads
