• 04.10.2026, 03:54
DCarey
Asus P6T Deluxe block?
Sunday, December 28th 2008, 4:42pm
Has anyone heard any rumors about an Asus P6T Deluxe chipset block? I'm looking to buy one with a couple of 280GTX's early in the new year and was hoping to watercool everything. The motherboard itself doesn't look too difficult to cool as these pictures (Shamelessly stolen from http://www.bit-tech.net/hardware/2008/12…us-p6t-deluxe/1) show
This post has been edited 1 times, last edit by "DCarey" (Dec 28th 2008, 4:46pm)
Sunday, December 28th 2008, 5:51pm
For the chipset you can use two twinplex blocks and for the voltage regulatores we are already working on a block which will be availabe soon.
rocky61
Wednesday, December 31st 2008, 12:01am
Unless you will be doing something insane, I doubt you will ever need to cool the chipset. I am using a RE2 and OC'ed to 4.2 and absolutely no trouble at all. Then again, if you are going to go all out and want the sexy look, go for it.
DCarey
Wednesday, December 31st 2008, 7:57pm
I was hoping to just have one block on the chipset, to replace the standard heatsink as it looks really easy to do, the reason I want to cool it is my current Asus M2N32 WS Pro still reaches temperatures of 65-70DegC with a large 120mm fan covering the standard heatsinks on the heatpipe. I was hoping to get temps lower than that when I upgrade.
rocky61
Thursday, January 1st 2009, 1:49am
When I cannot find Aqua blocks I use MIPS. Their blocks work very well with AC gear. The MIPS blocks are G 1/4 and will work with low flow. HTH.
http://www.xtremesystems.org/forums/showthread.php?t=210834
DCarey
Saturday, January 3rd 2009, 2:27am
That looks ideal, thank you
