• 12.10.2026, 17:03
Malik
Poweradjust and laing D5
Monday, February 16th 2009, 10:20pm
I have question about poweradjust panel - can i plug in laing d5 to this panel ? Or this pump is to voltage strong for him ? :)
CPU: Intel QX 9650
Mobo: Asus Rampage Formula
Mem: Apogee GT 4GB
Sound: Asus Xonar D2
GPU: EVGA GTX 280 FTW
Power: Antec Signature 850W
My LC Project
Top_Nurse
Tuesday, February 17th 2009, 5:58am
Quoted from English manual:
"Maximum current output capacity at 12 V is 2.5 A (30 W total power).
The maximum current output capacity also is reduced at lower output
voltages!"
One other point is that the big voltage regulator can itself be water cooled if you are running your poweradjust on the ragged edge.
This post has been edited 1 times, last edit by "Top_Nurse" (Feb 17th 2009, 6:00am)
rocky61
Tuesday, February 17th 2009, 6:49pm
So does this mean you can use the D5 with the Aquaero? It appears it would work the D5 nominal power at 12V is 24W and the current @ 12V is 2 amps.
This post has been edited 1 times, last edit by "rocky61" (Feb 17th 2009, 6:55pm)
Top_Nurse
Wednesday, February 18th 2009, 2:29am
We weren't discussing the Aquaero, but the Poweradjust. Also keep in mind that there at least two different versions of teh Aquaero in regards to the voltage regulators (VR) for fans. I don't know if any changes were made in regards to the VR's for the pump circuitry.
The pump does not plug directly into the Aquaero, but through the pump circuit board which is integrated into the Aquaero via a ribbon cable.
rocky61
Wednesday, February 18th 2009, 6:12pm
Yes, I know that it plugs into the pump circut board. I just want to know if the D5 will work, without blowing up the Aquaero or the pump board.
Top_Nurse
Wednesday, February 18th 2009, 10:58pm
The D5 won't work on the Aquaero using the Aquastream pump board. The Aquastream uses AC voltage and I think the D5 is a DC pump correct? However, I think the Poweradjust board would probably work for you. Especially if you use one of the little water coolers on the circuit board.
