• 28.09.2026, 14:33
nicky_82
Help please..
Monday, February 23rd 2009, 12:35am
Hi Guys
I was wondering if you could help me kind of confused ?( now what I'm doing is am going to be running these items right?
aquaero 4.00 USB Fan-Controller, VF-Display
Aqua Computer Poweradjust USB can I run two pumps of this ? also what's the dif between this and the multiswitch USB 1.41 and also can I run everything of a multiswitch USB 1.41
my res will be a aquatube also will be using a tubemeter USB fill level sensor
This post has been edited 1 times, last edit by "nicky_82" (Feb 23rd 2009, 12:42am)
Swing Swing :P
Monday, February 23rd 2009, 9:34pm
The poweradjust can only handle one pump. Two pumps generate too much load and will damage the poweradjust!
The multiswitch was mainly designed to switch things on or off, or to dim them in 26 steps. You can not use it for a Laing pump.
I would recommend to connect the tubemeter to the aquaero. You will need a special cable to do so: http://shop.aquacomputer.de/product_info…roducts_id=1969
nicky_82
Wednesday, February 25th 2009, 1:35pm
thank you
This post has been edited 3 times, last edit by "nicky_82" (Mar 5th 2009, 3:40pm)
Swing Swing :P
