• 08.10.2026, 06:14
Top_Nurse
(Aquaero + two Aquastream) + (Poweradjust) or (Aquastream XT) = working condition?
Thursday, March 5th 2009, 9:00am
I have been perusing the Poweradjust manual and see that it doesn't use an interface to the Aquaero like the Aquastream (old style) does. Is it possible to use the Aquero to control my two Aquastream pumps + one Poweradjust for a total of three (3) pumps through the Aquasuite interface? The demo wasn't clear on this subject.
EDIT:
So can I hook two older style Aquastream pumps to the Aquaero and an Aquastream XT directly through a USB interface and control all three (3) pumps through the Aquasuite interface?
This post has been edited 3 times, last edit by "Top_Nurse" (Mar 7th 2009, 2:14am)
Monday, March 9th 2009, 9:44pm
The poweradjust will always run independent from all other devices. So you can connect it via USB while you can connect the older aquastream pumps with the external controller to the aquaero.
A third aquastream XT can not be connected to the aquaero because it can only handle two pumps at once. Since the aquastream XT offers MUCH more possibilites only through USB that should be no real problem.
Whatever you connect to your PC: the aquasuite will show it all. 5 aquastream XTs, 3 aquaeros, 2 poweradjust and 20 aquaeros - you will be able to control them :D
(only an example, you can use hundreds of our devices on one PC if you are crazy enough)
Top_Nurse
Monday, March 9th 2009, 9:57pm
Excellent! Now I can have full control over all three loops on my Feeding Frenzy project. :thumbsup:
