• 29.11.2026, 22:42
WebMaximus
Broken Aquaduct 240 PRO...?
Thursday, March 5th 2009, 4:14pm
Today when I started my computer my Aquaduct 240 PRO didn't start with the computer as it usually does, the pump nor the fans are running and I'm only lucky I noticed this right away so I didn't boil my computer.
Any idea what might have happened and how and if I could possibly fix it? I really hope I don't have to send in the unit for repair because I use my computer every day. I have verified I have current at the end of the 15-pin power cable that goes into the Aquaduct so I guess whatever is wrong it's within the Aquaduct. Guess I could try to take the Aquaduct apart and see if I can find out what is wrong myself but thought I would ask you for advice before doing so.
Thanks alot in advance for your help!
Richard
This post has been edited 1 times, last edit by "WebMaximus" (Mar 5th 2009, 4:22pm)
Top_Nurse
Thursday, March 5th 2009, 8:19pm
Be very careful about taking it apart as it is difficult to go back together. Does this unit have an Aquaero?
WebMaximus
Friday, March 6th 2009, 4:00am
Not sure what an Aquaero is but if you mean a LCD display of some kind, no it doesn't have that. However I after posting my first post dared to boot all the way into Windows after my CPU had cooled down. Reason I wanted to do this was to check what the Aquasuite software would say but it didn't even find my device anymore so I guess that pretty much says it all...my Aquaduct device for some strange reason is totally dead so now I'm waiting for a response from aquacomputer support how to solve this as easily and quickly as possible because I only had my device for a couple of weeks and I expect the lifespan to be a little bit longer than this...!
Similar threads
