• 06.10.2026, 10:59
drbo
Voltreg cooler for MSI Eclipse? (solved)
Thursday, March 5th 2009, 11:27pm
I am wondering about purchasing a new mobo, MSI Eclipse ...
As far as I can see, the nb and sb should be fine using Twinplex
But I cant seem to find any waterblocks for the voltreg ...
Any suggestions? Thanks in advance
EDIT 10/03/09: I have decided not to purchase this mobo, so the question isnt valid anymore. Thanks for all help
drbo 8)
This post has been edited 1 times, last edit by "drbo" (Mar 10th 2009, 3:27pm)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
Top_Nurse
Friday, March 6th 2009, 9:17pm
Check out the dimensions here in this file and compare to your board.
http://www.aqua-computer.de/download/Mainboard+twinplex.pdf
drbo
Friday, March 6th 2009, 9:33pm
Thanks Top_Nurse, I have looked at that file alot, but I did not find anything the looked the right shape. 8)
The eclipse har a rather strange layout for the voltreg. But then again it is seperate from nb and sb, so i might just skip the voltreg ...
Top_Nurse
Friday, March 6th 2009, 11:46pm
I was going to wait for mb components for my new Gigabyte board, but I think it might be a while before they decide if they even want to make them. ;(
So I'm leaving in the stock heatsinks and just water cooling the CPU, GPU's and the hard drives. 8o
As you can see it is difficult to get a cooler into the south bridge. I think this board needs a special block like a stretch limo. :D
This post has been edited 1 times, last edit by "Top_Nurse" (Mar 6th 2009, 11:51pm)
Papa_Schlumpf
Monday, March 9th 2009, 9:15am
Do you want to OC? If not the HP is enough. The i7 Chip doesent make any heat at all. I have the ultra version. With 620@4000 the HP is not realy warming up.
drbo
Tuesday, March 10th 2009, 3:23pm
Actually, I am having second thoughts aboout the i7, and is going for a Phenom II 940BE instead.
So now I looking for a voltreg watercooler for ASUS M3A78-T instead 8)
Thanks for all help.
