• 06.10.2026, 17:57
Top_Nurse
Asus 4870 1Gb full cover cooler?
Tuesday, March 31st 2009, 11:47am
Is there any AC full cover blocks that will fit the circuit board of the Asus 4870 1Gb video card? From what I have read this board is the same board that will be used for the upcoming 4890 board.
Tuesday, March 31st 2009, 4:00pm
That card is not compatible to our HD4870 blocks. That card has also a different layout compated to the HD4890. The HD4890 looks very similar to the initial reference layout (typ 1) but is also not compatible.
Top_Nurse
Wednesday, April 1st 2009, 1:59am
Well not entirely unexpected as ASUS plays to a different drum.
So if I use a TwinPlex for the GPU and leave on the power heat sink will just a normal air flow in a case be sufficient to cool it off? Or will I need a fan blowing directly on the card?
I can also add some copper heat sinks to the ram, but is it really necessary?
Wednesday, April 1st 2009, 1:33pm
The RAM on HD4870 cards get VERY hot - I would not use it without any addtional cooling!
A pssive block with some airflow on the voltage regulators should be enough since also a few other cards use it this way. Anyway, I can't ensure that it will work without any problems.
Similar threads
