• 12.11.2026, 17:31
SteinerKD
Internal USB splitter cable
Friday, April 10th 2009, 5:27am
This is something I think many Aquaero users etc would like. I don't know if I'm missing something, but why is there nothing like it on the market (at least that I can find).
I'm not talking about splitting a single USB port into severall but rather fanning out the two available ports in a internal dual port USB connector into two cables each ending in an internal single port contact. Most of the time you get something like it with your motherboard only it ends in two external ports on a backend bracket instead.
Looking for example at the Asus P6T6 WS Revolution it has 3 dual headers internaly, each looking like this
12345
1234-
Where upper row is one port and lower row another port (5th pin upper row not connected)
1= +5v, 2= -, 3= +, 4= GND
Am I missing some technical difficulty with making such a splitter since they seems non existant??
Only thing I can see directly from the Aquaero manual is that it uses a 5 pin layout with 2 ground wires, could that realy be a deal breaker?
MrToad
Saturday, April 11th 2009, 3:36am
Am I missing the point on there's no point on this?
What's the difference between connecting two single row wire-to-board housings or a single double row housing?
And if that bothers you, you can always "salvage" a double row housing from a double port bracket (the female pins release lifting carefully the latch on the housing), remove the single row housing from the two cables, and plug the pins in the double row housing.
Edit: By the way, the 2nd ground wire is the cable's shielding (the wire mesh wrapped around the conductors).
This post has been edited 1 times, last edit by "MrToad" (Apr 11th 2009, 4:00am)
Top_Nurse
Saturday, April 11th 2009, 7:41am
I'm not sure what your question is, but I want to make sure you understand that the Aquaero pin assignment is not a standard MB USB header configuration. On a MB the #1 pin is hot and on the Aquaero the #5 pin is hot. I think a lot of people hook the Aquaero up backwards and I just want to save you some grief. :)
Edit: Went back and reread your OP. The reason there is nothing on the market is that you can easily buy a single USB cable or make your own double yourself. The Aquaero comes with a single USB cable that is intended to hook up to a MB header.
This post has been edited 1 times, last edit by "Top_Nurse" (Apr 12th 2009, 3:30am)
torres
Reply
Thursday, May 14th 2009, 8:39am
Thanks
Similar threads
