• 20.11.2026, 15:09
1komling
Can i use my 4870 waterblock on a 4890?
Friday, June 12th 2009, 10:48pm
I got a 4870 waterblock, and it looks almost the same as the 4890 waterblock.
Can i use it on a ati sapphire 4890? The 4870 waterblock i got is the same as product no 23459 on aquacomputer.
I wanted to buy two 4890 and only 1 waterblock if i could use the old one.
Hope somone can help me :wacko:
Saturday, June 13th 2009, 4:58pm
Welcome to the forum :)
That won't work. The HD4890 ist sligthly different from the HD4870. An old HD4870 block will not fit on a HD4890 card, but the new HD4890 blocks are also downwards compatible to the HD4870 cards.
jamesjeans
Thursday, July 9th 2009, 11:57am
There is a some certain differences in new 4890 and the older 4870. But new 4890 has down ward compatibity and can be used with 4870 card but not vice versa.
Top_Nurse
Monday, July 20th 2009, 11:09pm
Hi Shoggy...
So will the new blocks fit my Asus 4870 (Dark Knight series) with the 1Gb of ram?
Tuesday, July 21st 2009, 12:02am
Your card must have one of these layouts:
Otherwise it will not work. There are too many different layouts to say for sure if card X will work.
nickadams123
Tuesday, July 21st 2009, 12:27pm
I think you can't use 4890 with 4870. However, HD4890 is compatible with 4870.
b0nez
Tuesday, July 21st 2009, 12:37pm
Belive Shoggy, the 4890 Block is downwards compatible to the 4870 as long as the Layout is correct.
:rolleyes:
jamesmilner
Monday, August 3rd 2009, 7:03am
Hey 1komling
I don't think that it will work for you as 4890 is the latest model with quite new features so 4870 waterblock would not work on 4890
Top_Nurse
Tuesday, August 4th 2009, 9:08am
So will this layout be good or not? If not, would I be able to either mod it with a dremel or a Bridgeport mill without going into the water channels?
Similar threads
