• 23.11.2026, 01:39
markcu
Suck or Blow?
Saturday, June 13th 2009, 10:53am
Hi, when mounting fans on a radiator, should they blow, eg push air through the radiator, or suck, eg pull air through the radiator? Many Thanks, Mark.
hobbes_dmS
Saturday, June 13th 2009, 11:34am
some say that fans will work a little more quiet when sucking (less turbulences)
however it is always a good idea to get the hot air out of the case (no matter how the fans are mounted on the radiator)
majorblue
Monday, June 15th 2009, 7:34am
It is better to "suck" through the radiator.
The advantages are:
1. The hot air is "sucked" out of the case.
2. When you "suck" the air out of the case, fresh air flows into the case because of the low-pressure.
If you "blow" the air through the radiator, the air in the case will be very hot and you can not cool down the computer components so well.
Kind regards.
"Man kann nicht immer gewinnen! Wer es aber nicht versucht, hat schon verloren."
fox3
Monday, June 15th 2009, 5:18pm
You will want to use your fans to pull cooler air thruogh the rad. All tests I have read show that push works better at higher fan rpm's at 1500 and above. If you are using a quieter solution, under 1500 rpm, than pull is the way to go.
If your rad is located in your case than you might want to consider pulling cooler air across the rad and into the case for the best cooling results and use case fans to control case temps. You do not want to use warmer air from the case to coll the rad as your temps will suffer and your cpu and other blocks will run hotter.
jimtaylor
Wednesday, July 29th 2009, 11:57am
I think sucking would do some better as it would cause low pressure..which is good.
This post has been edited 1 times, last edit by "jimtaylor" (Jul 29th 2009, 11:58am)
Beaker
Wednesday, July 29th 2009, 9:04pm
hmmmm suck or blow.....
ask your girlfriend :evil:
jerome ablin
Sunday, August 2nd 2009, 10:43pm
suck is more effective, it suck the hot air away.
This post has been edited 1 times, last edit by "hobbes_dmS" (Aug 4th 2009, 10:32pm)
hobbes_dmS
Tuesday, August 4th 2009, 10:33pm
jerome, I'm shure yoiu meant this in a funny way, but we don't want Links like that in our Forum...
webbyweb
Thursday, August 6th 2009, 12:37pm
go on sucking ...lolz!! :D :D
rhino1
Tuesday, August 18th 2009, 11:46am
hehehe... Funny. but Sucking would be fine for you.
Top_Nurse
Tuesday, August 25th 2009, 4:59am
Unless you are looking for uber temp control I don't think you will find a discernible difference. I Iput them in whatever way is easiest and looks the best.
nickadams
Wednesday, August 26th 2009, 6:39am
it does matter whether to suck or blow. Try that best suits your needs for keeping the temperature low
defender777
Thursday, September 3rd 2009, 7:48am
sucking will give better results as it will take hot air out of the case hence causes decrease in temperature.
Top_Nurse
Friday, September 4th 2009, 10:39am
You really sure about that? ?(
Similar threads
