• 19.11.2026, 06:23
Top_Nurse
ASUS Crosshair III AM3 support?
Sunday, June 21st 2009, 5:39am
Not been very happy with my Gigabute UD5 AM3 board so I just picked up an ASUS Crosshair III Formula AM3 motherboard. Should be here next Tuesday. :D
Anyone know if AC plans to support voltage regulator water coolers for this board? I already have the chipset coolers for the NB and SB (Twinplex's) and a Cuplex XT for the CPU.
Top_Nurse
Wednesday, June 24th 2009, 9:28am
Got the board in my hot little hands now. Don't think a standard Twinplex is going to fit on this SB. The standard Twinplex will fit on the NB no problem. I think this needs one of those combined NB/SB coolers I have seen for other boards. So back to my original question...HELP! ;(
cuto8
Wednesday, June 24th 2009, 9:44am
Just print this with "fit to page" disabled and you should see which coolers you need...
Top_Nurse
Wednesday, June 24th 2009, 11:44am
Thanks, I forgot about that. ?(
Seems that it is about 118 mm in length center to center for the voltage cooler so it appears this would would be the closest choice. What I need to know is exactly how wide this block is as there isn't a lot of room on this board.
b0nez
Wednesday, June 24th 2009, 6:09pm
If the length center to center ist 118mm, the cooler you choosed isnt the right one.
This will fit in by length.
The dimensions are 15 x 123 x 18 according to the page i linked above.
:rolleyes:
