• 18.10.2026, 18:57
heed
Aquasuite error
Monday, August 3rd 2009, 7:13am
In english, it means "database cannot be opened", in German it's: "datenbank konnte nicht geoffnet werden"
I'm using XP 32-bit SP3, Aquasuite version 4.66.00. In the german forum, someone recommended to another person having the same problem to install Microsoft Data Access Components, so I tried that. It said that it was already included in my OS.
Does anyone have an idea of how to resolve this error? Thanks!
Monday, August 3rd 2009, 8:50pm
Try to reinstall the aquasuite and remove the rest by hand after deinstallation.
heed
Wednesday, August 5th 2009, 8:02am
Hi, Shoggy, thank you for your reply!
I tried uninstalling the Aquasuite, then manually deleting the directory from Program Files. Then restart, then reinstall.
But I still get the same error, right when I start Aquasuite. It seems like the other functions work okay, though it's a little annoying and worries me a little.
Do you have any more ideas?
Wednesday, August 5th 2009, 9:55pm
Mhhh, you could check the access rights of all necessary folders.
ka0t
Thursday, August 27th 2009, 4:47pm
I did recently have this problem as well.
It was caused by a missing folder (my virtual ram- drive crashed - so the temp- folder could not be accessed )
Similar threads
