• 04.10.2026, 03:10
Cyberdyne
Whether repair my pump?
Tuesday, August 11th 2009, 6:02pm
Confronted with an issue. Improperly connected cable USB pulling the +5 V is on the other connector (Pin 4 D-). Then, of course, ceased to operate the software. I want to ask - my pump is beyond repair or electronics will not recover?
I lifted the hood and checked all the diodes. This diode was burned. Unfortunately, I do not know what the face value can be replaced. Here is his picture:
Please forgive me for my English - it is not my native language. I look forward to a reply.
This post has been edited 1 times, last edit by "Cyberdyne" (Aug 11th 2009, 6:06pm)
Cyberdyne
Wednesday, August 19th 2009, 11:32am
Defence1
Friday, August 21st 2009, 8:44am
send it over to Aqua Computer, they can repair your pump. you can fix it even by yourself, simply change the diode.. The type can be named by Aqua Computer....
Mein System:
Cyberdyne
Monday, August 24th 2009, 6:03pm
Thanks, I'll try to replace the diode itself. Are transferred to other countries are very far (and expensive).
Cyberdyne
Monday, August 24th 2009, 6:07pm
Sven - thank you for additional information, I hope it will help
PvHooijdonk
Tuesday, August 25th 2009, 2:17pm
The same thing happened to me some time ago.
Due to the fact that I did not notice in time that the colouring of the usb wiring was different than standard.
I tried to change the zener-diodes myself but was unsuccesful.
I ended up buying a replacement print plate for the pump via AC.
Professional Crasher :thumbsup:
kolsols
Saturday, September 12th 2009, 7:54am
yes pf course simply replace your burnt diode with a new one and your pump would be fine.
Cyberdyne
Monday, September 14th 2009, 8:56pm
I ordered a new diode - it will be soon to come. After replacing the diode, I will inform the result of repair
mans123
Thursday, September 24th 2009, 9:06am
hope it would be fine.
copcop
Monday, October 12th 2009, 11:53am
I think you should buy a new one instead of repairing it. :P
Top_Nurse
Tuesday, October 13th 2009, 3:06am
Why? There easy to fix. :thumbsup:
funkyfresh123
Friday, October 30th 2009, 10:54am
just try to repair it...as it would be cost effective.
Cyberdyne
Sunday, November 8th 2009, 10:16am
Replacing the diode has not helped. Died controller (((
The controller has been filled with resin. Had some work to clean it.
The question now is - if I changed to a working chip (ATMEL), will need special firmware or will be enough this - aquastream XT-Firmware 1.09, DIY-Flasher?
This post has been edited 1 times, last edit by "Cyberdyne" (Nov 8th 2009, 10:29am)
Monday, November 9th 2009, 4:35pm
That will not work in any way...
You will need a completley different firmware.
brianmoore123
Wednesday, November 11th 2009, 11:55am
I think someone has already advised you not try to repair
