• 30.11.2026, 15:53
Pumpkin
Aquaero Power Connect & Relay Query
Friday, August 14th 2009, 8:51am
I am trying to set up a emergency shutdown of the PC
I am using the following accessories, Product No.: 53047and the Product No.: 53036
I connect the Standby Power cable into the Aquaero
I cut the green ATX PS_ON line and attach the Relay plug and connect it to the Aquaero
I turn on the PSU
The problem is when I try and power on the PC nothing happens. (I am using the onboard power button on the EVGA E759 Classified MB)
However if I reconnect the ATX PS_ON line without the Relay Plug then the PC will boot up fine with or without the Standby Power plug connected to the Aquaero.
What am I doing wrong....
This post has been edited 3 times, last edit by "Pumpkin" (Aug 14th 2009, 9:19am)
Friday, August 14th 2009, 9:52am
Have you set the jumper on the aquaero for the standbypower?
Pumpkin
Friday, August 14th 2009, 10:05am
Similar threads
