• 12.10.2026, 20:04
Pumpkin
Alarm Settings
Friday, August 14th 2009, 7:10pm
Currently I have setup my aquaero such that if any of my sensor hit a certain temp then my PC shuts down.
My settings are "Software emergency shutdown" screen
Enable emergency shutdown - ON
Play sound when alarm occurs - ON
Loop sound - ON
Choose sound - Link to my .wav file
Alarm timeout in sec - 1
Emergency shutdown in sec - 2
Shutdown PC - ON
Sensor 1 - ON
Sensor 2 - ON
Now this works fine.
However how do I set it up such that when either temp sensor hits there alarm threshold (alarm threshold temp set lower than for an emergency shutdown temp) that it just play the alarm and not do a shutdown and restart
This post has been edited 1 times, last edit by "Pumpkin" (Aug 14th 2009, 7:12pm)
Pumpkin
Monday, August 17th 2009, 2:02pm
No one has any ideas??
Pumpkin
Thursday, August 20th 2009, 9:12pm
Bump. Shoggy you have no ideas? is it possible?
Friday, August 21st 2009, 9:37am
In the tab emergency software shutdown you have to set the option play sound when alarm occurs and below you can set a larger timeout if you also want to shutdown the system after X seconds.
